04-20-2015 06:59 AM
Wen configuring the following, multicast-optimize command is not support on Nexus 5672UP, while, it is support on Nexus 5548UP
policy-map type network-qos jumbo
class type network-qos class-default
mtu 9216
multicast-optimize
Is there an QoS implementation difference between Nexus 5672UP and 5548UP?
In what situations should the multicast-optimize be used on the switch?
Will it influce unicast traffic when multicast-optimize is enabled?
Does it work on 40G interface?
Kind regards,
Lijun
10-06-2015 01:50 AM
Well this is dissapointing... noone anwered in 6 months, and I have the exactly same problem...
10-12-2015 09:15 AM
The multicast optimize command only applies to Nexus 5000 and Nexus 5500, it is
not supported nor needed on Nexus 6000 / 5600. I think the config guide incorrectly mentions it as well for the 5600 platform. Let me see if I can have that removed for the benefit of others having the same query.
-Raj
11-05-2015 11:57 AM
config guide incorrectly mentions, still not removed after a month
