04-20-2015 12:43 PM
A little help for a new Cisco user. I have an RV325. Need to connect Win 7 and Win 8 clients to the router. Started SSL VPN config, and its interesting, but just want to set up a client software on our external laptops to access network. We have 5 locations with RV042s connecting into the RV325 through site-to-site vpn. How can I give the clients access to RV325 and be able to cross to servers on the different subnets? and what client software should I be using? PPTP is not enough. Any help would be appreciated.
04-22-2015 03:11 AM
I use Shrew Soft vpn-client, it works on tunnels and easyvpn tunnels, havent got it working on groupvpn tunnels yet but i havent had the time to work on it. Also the latest version of Cisco EasyVPN client works on W7/W8.x x64 but it is not easy to get hold of since it is eol and not bundled by Cisco anymore.
04-22-2015 06:10 PM
stpa67001 thanks for your help. I got the old cisco vpn client working with the 325. But I am still a little confused whether to be setting my rv042's and rv325's as routers or gateways. Any idea?
04-23-2015 03:24 AM
Gateway mode since i guess you are connecting each router to internet behind a nat/firewall and using non routable private ip's.
10-12-2015 07:17 AM
Just bought a brand new RV325, and discover I can not get EASYVPN software because it is EoL.
Seriously ? Can not believe this restriction with Cisco.
Trying to connect ShrewSoft, but did not manage it to work getting a "received peer INVALID-ID-INFORMATION notification".
I manage to connect Shrewsoft with many Linksys or Cisco, like RV082, but here, I can not manage to make it works.
You told me you perform to work with normal Tunnels and EasyVPN Tunnel.
May I aks what you use in Shrewsoft Local and Remote ? For EasyVPN, which parameters did you use ?
Thank you
