04-20-2015 02:18 PM - edited 03-17-2019 05:05 PM
Dears,
I am facing a strange issue on client site. Here is the setup
Client has CUCM Pub and Sub with two gateways; one GW configured for SIP trunk towards ITSP and second GW as E1 towards PSTN.
There are different telecom companies in Saudi Arabia like Zain, Mobily, STC which is having numbering for as below
Zain Telecom.
058XXXXXXX
059XXXXXXX
Mobily
056XXXXXXX
054XXXXXXX
STC
050XXXXXXX
053XXXXXXX
055XXXXXXX
Problem:
dialing to the Zain network always work fine.
dialing to the Mobily network sometimes give busy on some mobile numbers. After trying 5,6,7,8,9 times busyouts using redial button; call then finally goes and connect.
dialing on STC network almost always gives busy and after 6,7,8 or 9 times busyouts; call then finally goes and connect.
This problem is with DIDs on both SIP and E1
Need help to figure it out.
04-20-2015 02:40 PM
Start by debugging those calls to find out the disconnect cause telco is sending, depending on that, you would need to find out if they are expecting some special formatting for the calls to always work, or if there is some problem between telcos handling the calls.
04-21-2015 12:41 AM
Thanks for the reply,
I will visit the site and update the status later on. On the same configuration this setup was working fine. This issue suddenly came a week ago.
04-22-2015 01:59 PM
Replied on the other thread:
https://supportforums.cisco.com/discussion/12486626/500-server-internal-errorvia-sip20udp-and-sip20-503-service-unavailablevia
Mohsin, kindly let's keep working on single thread as I saw you created another two threads after this one.
04-22-2015 09:55 AM
