04-21-2015 07:33 AM
HI
I have to ASR9010 to be a NvEdge Systems.and i need get a BNG in my ASR9010
this is my configuation
now subscribers can creating the session by BNG,and register in the CoA(PortServer) and Radius Server
but my account have a problem, in my show subscriber session all detail,i can see the username and COA pushed username
RP/0/RSP0/CPU0:ios#show subscriber session all detail
Mon Apr 20 23:24:02.171 UTC
Interface: Bundle-Ether100.2.ip12
Circuit ID: Unknown
Remote ID: Unknown
Type: IP: Packet-trigger
IPv4 State: Up, Mon Apr 20 23:23:42 2015
IPv4 Address: 49.52.9.119, VRF: default
Mac Address: Unknown
Account-Session Id: 0000028d
Nas-Port: Unknown
User name: test1 <------------------------------there
Formatted User name: unknown
Client User name: unknown
Outer VLAN ID: 2
Subscriber Label: 0x00000052
Created: Mon Apr 20 23:23:42 2015
State: Activated
Authentication: authenticated
Authorization: unauthorized
Access-interface: Bundle-Ether100.2
Policy Executed:
policy-map type control subscriber IP_PM
event Session-Start match-first [at Mon Apr 20 23:23:42 2015]
class type control subscriber IPoE do-until-failure [Succeeded]
5 activate dynamic-template IP_SUB [Succeeded]
10 activate dynamic-template HTTPR [Succeeded]
20 set-timer UNAUTH_TMR 1 [Succeeded]
event Account-Logon match-first [at Mon Apr 20 23:23:53 2015]
10 authenticate aaa list ECNU [Succeeded]
20 deactivate dynamic-template HTTPR [Succeeded]
Session Accounting:
Acct-Session-Id: 0000028d
Method-list: ECNU
Accounting started: Mon Apr 20 23:23:42 2015
Interim accounting: On, interval 10 mins
Last successful update: Never
Next update in: 00:09:41 (dhms)
Last COA request: Mon Apr 20 23:23:53 2015
COA Request Attribute List: 0x1000f0c4
1: addr len= 4 value= 49.52.9.119
2: password len= 6 value= <opaque value>
3: username len= 5 value= test1 <------------------------------there
4: command len= 14 value= account-logon
Last COA response: Result ACK
COA Response Attribute List: 0x1000f2d4
but my radius Server can't see the username of the Session
radius Server only can see the username(mac) in the IPoE L2 session, and see null in the IPoE L3 session
what wrong of me?
thanks
Solved! Go to Solution.
04-29-2015 04:44 PM
Hi, looks like we need more to investigate here. Can you please share the image details and show platform ? Do you have all the mandatory SMU's installed ?
04-23-2015 06:26 AM
it looks like you have accounting enabled on your services.
the services that were defined as subscriber templates may not have gotten notification that
the username was updated.
try this:
1) convert the templates for the services from ipsubscriber to service
or
2) alternatively, remove the accounting directives from the templates and when the user logs on, provide the subscriber:accounting directive in the coa account logon profile to start subscriber accounting.
xander
04-29-2015 12:50 AM
hello i'm so sorry to see the problem too late
i am testing the BNG in the ASR9010 all of week
1.now i config the account and a new problem occur
when the subscriber logging on , when occur the logging
LC/0/1/CPU0:Apr 29 15:25:52.829 : prm_server_ty[314]: %PLATFORM-NP-3-DIAG : NP-DIAG failure on NP1, STS-0 = 0x00400000 MDF0-level cause 0x100
LC/0/1/CPU0:Apr 29 15:25:52.833 : pfm_node_lc[301]: %PLATFORM-NP-2-NP_DIAG : Set|prm_server_ty[172114]|0x1008001| NP diagnostics warning on NP1.
LC/0/1/CPU0:Apr 29 15:26:10.991 : prm_server_ty[314]: %PLATFORM-NP-4-FAULT : Fast Reset NP1 - successful auto-recovery of NP
LC/0/1/CPU0:Apr 29 15:26:10.991 : pfm_node_lc[301]: %PLATFORM-NP-2-NP_DIAG : Clear|prm_server_ty[172114]|0x1008001| NP diagnostics warning on NP1.
LC/0/1/CPU0:Apr 29 15:27:07.358 : prm_server_ty[314]: %PLATFORM-NP-3-DIAG : NP-DIAG failure on NP1, STS-0 = 0x00c00000 MDF0-level cause 0x800
LC/0/1/CPU0:Apr 29 15:27:07.359 : pfm_node_lc[301]: %PLATFORM-NP-2-NP_DIAG : Set|prm_server_ty[172114]|0x1008001| NP diagnostics warning on NP1.
LC/0/1/CPU0:Apr 29 15:27:24.595 : prm_server_ty[314]: %PLATFORM-NP-4-FAULT : Fast Reset NP1 - successful auto-recovery of NP
LC/0/1/CPU0:Apr 29 15:27:24.595 : pfm_node_lc[301]: %PLATFORM-NP-2-NP_DIAG : Clear|prm_server_ty[172114]|0x1008001| NP diagnostics warning on NP1.
when the three fast reset in a hour ,my MOD80 SE will all down
so i can't know why will cause it?is my config is error?
04-29-2015 04:44 PM
05-13-2015 06:17 AM
thanks a lot
i have a case,and the R&D give me a new SMU to resolve the ASR9010 SE shutdown
the config i and tac will finish it
thanks
