Hello, we have two routers connected as shown below:
{Please, view image and zoom in to full scale for clearer reading!}
With this configuration, the tunnels 7 and 8 seem to be working correctly, however when we switch traffic between Site 1 (R1) and Site 2 (R2) so that it goes through the tunnels rather than through the ISP, then netflow export from R1 to our netflow server (using nfdump/nfsen) which is located at a LAN connected to R2, is not recorded correctly; I see (on R1):
# sh ip flow export
Flow export v9 is enabled for main cache
Export source and destination details :
VRF ID : Default
Source(1) 195.251.xxx.yyy (Loopback0)
Destination(1) 195.251.xxx.xxx (9995)
Version 9 flow records
680074 flows exported in 8490 udp datagrams
0 flows failed due to lack of export packet
1579 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
and after that I find that our traffic is not recorded correctly.
When we don't use these tunnels to route traffic between R1 and R2, then "export packets sent up to process level" are 0 and netflow export works correctly.)
Can you please help identify the cause of this problem and suggest a solution?
Please advise.
Nick
