Web Passthrough with ISE for guest wireless? (only email address is needed to join the network)
sysmalainen
Hi all,
Is it possible to configure "Web Passthrough mode" with email Input for wireless guest network with ISE? So the users would only be prompted for their e-mail address when attempting to connect to the network and no authentication what so ever would be needed.
Many thanks
5 Replies 5
abwahid
Level 4
Level 4
I don't think so, we have this type of feature in ISE uptill now
jacob
On the WLC it's easy out of the box, right?  Just WLAN > Security > Layer 3 > Web Policy > Passthrough and there is a nice little checkbox for "email input"
But for ISE you can set up a Self-Registered Guest portal (Guests can also create their own accounts, which you can configure as auto-approved) these accounts will have names and passwords and email addresses!
http://www.cisco.com/c/en/us/td/docs/security/ise/1-3/admin_guide/b_ise_admin_guide_13/b_ise_admin_guide_sample_chapter_01111.html#ID32
Hope that helps!
Majorbacon
mohanak
Web Passthrough
This is a variation of the internal web authentication. It displays a page with a warning or an alert statement, but does not prompt for credentials. The user should click ok. You can enable email input, and the user can enter their email address, which becomes their username. When the user is connected, check your active clients list; that user is listed with the email address they entered as the username. For more information, refer to the Wireless LAN Controller Web Passthrough Configuration Example.
Great reference link Mohanak!  The original question was if this could be done centrally using ISE instead of locally on the WLC. Any thoughts on that?
ali aqrabawi
Level 3
Level 3
to answer your question we need to know what is the role of the ISE will be ?
will the ISE be acting as NAC server like in CWA ? or it will only act as web server and radius server ? .
if the ISE will act as NAC , then ask your question here :
https://supportforums.cisco.com/community/5936/aaa-identity-and-nac
if it will be webserver/radius server , then do what  jacob mentioned
