04-22-2015 01:44 AM - edited 07-05-2021 02:59 AM
Hello Cisco-WLAN-experts,
we are troubleshooting right now Apple devices on Cisco WLAN and I'm wondering about the
statistics shown under "show client detail MAC" in the WLC-CLI running version 7.4.130
Unfortunately there is no help nor actual screen-shot showing the correct output of this command
in the Command-reference guide for this release.
Here is an example output cutted with only the interesting lines:
Client MAC Address............................... 00:24:d7:a3:59:8c
Client Username ................................. host/NLNIECND1124FP2.corp.skf.net
AP MAC Address................................... 64:d8:14:36:af:70
AP Name.......................................... NLERC2K_AP05
Channel.......................................... 48
Radio Signal Strength Indicator............ -54 dBm
Signal to Noise Ratio...................... 43 dB
Nearby AP Statistics:
NLERC2K_AP05(slot 0)
antenna0: 121 secs ago................... -46 dBm
antenna1: 121 secs ago................... -53 dBm
NLERC2K_AP05(slot 1)
antenna0: 56 secs ago.................... -50 dBm
antenna1: 56 secs ago.................... -58 dBm
NLERC2K_AP03(slot 0)
antenna0: 121 secs ago................... -80 dBm
antenna1: 121 secs ago................... -76 dBm
NLERC2K_AP03(slot 1)
antenna0: 56 secs ago.................... -75 dBm
antenna1: 56 secs ago.................... -77 dBm
NLERC1C_AP07(slot 0)
antenna0: 525 secs ago................... -87 dBm
antenna1: 525 secs ago................... -89 dBm
NLERC2K_AP01(slot 0)
antenna0: 121 secs ago................... -82 dBm
antenna1: 121 secs ago................... -87 dBm
NLERC2E_AP07(slot 0)
antenna0: 122 secs ago................... -85 dBm
antenna1: 122 secs ago................... -87 dBm
NLERC1J_AP05(slot 0)
antenna0: 121 secs ago................... -78 dBm
antenna1: 121 secs ago................... -79 dBm
NLERC1J_AP03(slot 0)
antenna0: 121 secs ago................... -85 dBm
antenna1: 121 secs ago................... -92 dBm
NLERC1T_AP02(slot 0)
antenna0: 121 secs ago................... -96 dBm
antenna1: 121 secs ago................... -93 dBm
NLERC1T_AP03(slot 0)
antenna0: 121 secs ago................... -94 dBm
antenna1: 121 secs ago................... -95 dBm
The command shows Nearby AP Statistics and I would like to know:
Are the shown dBm-values the values measured by the WLAN Client itself showing how it sees the WLAN APs ?
Or are these values derived from the WLAN APs and show how good or bad they see the client ?
Here again the values for the connected AP which seems to be using 5GHz-band:
Client State..................................... Associated
A second question regarding the output for assisted roaming:
Assisted Roaming Prediction List details:
[0]=78 [1]=51 [2]=53 [3]=58
Is someone familiar with this cryptographic outout and can explain the sense behind it to me ?
Thank You for comments in advance.
wini
10-14-2019 07:38 AM
I know it was a long time ago but wondering if you go the answer to this?
06-03-2020 08:38 AM
Back to the top....trying to resurrect this one to see if anyone has an answer for the Nearby AP Statistics question.
Is this from the AP's perspective or from the client's perspective?
