04-24-2015 01:22 AM - edited 07-05-2021 03:01 AM
Hello. i have saerched but could not found.The controller and Access points works fine, but i have a problem like this: when i have a static ip address on cleint device, i can not access anything. when i set ip address to dhcp it is working fine without a problems.Software Version 7.0.250.0
please help.
04-24-2015 02:38 PM
Under WLAN-> Advanced tab, you may have tick "DHCP Address Assignment Required" option.
If you want static client to connect, remove this check box.
Rasika
*** Pls rate all useful responses ***
04-26-2015 11:44 AM
yes i know. this check box is not selected
