ASA - Certificate-authenticated AnyConnect/IKEv2 connections not obeying tunnel-group-map
Patrick0711
Level 3
Level 3
Hello Everyone,
I have the following configuration in place:
crypto ipsec ikev2 ipsec-proposal INTERIM
 protocol esp encryption aes
 protocol esp integrity sha-1
crypto dynamic-map DYNMAP 65535 set pfs group5
crypto dynamic-map DYNMAP 65535 set ikev2 ipsec-proposal INTERIM
crypto dynamic-map DYNMAP 65535 set security-association lifetime seconds 82800
crypto map VPNMAP 65535 ipsec-isakmp dynamic DYNMAP
crypto ca trustpoint vpn.domain.org-TP
 revocation-check crl
 enrollment terminal
 keypair vpn.domain.org-TP
 crl configure
  cache-time 720
crypto ikev2 policy 11
 encryption aes
 integrity sha
 group 5
 prf sha
crypto ikev2 enable outside client-services port 443
crypto ikev2 remote-access trustpoint vpn.domain.org-TP
webvpn
 enable outside
 anyconnect image disk0:/anyconnect-win-3.1.05160-k9.pkg 1
 anyconnect profiles IKEv2 disk0:/ikev2.xml
 anyconnect enable
group-policy ANYCONNECT-IKEV2-CESG internal
group-policy ANYCONNECT-IKEV2-CESG attributes
 wins-server none
 dns-server value 1.1.1.1 2.2.2.2
 vpn-session-timeout 1440
 vpn-tunnel-protocol ikev2 ssl-client
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value vpn-split-tunnel
 default-domain value domain.local
 webvpn
  anyconnect modules value vpngina
  anyconnect profiles value IKEv2 type user
tunnel-group ANYCONNECT-IKEV2-CESG type remote-access
tunnel-group ANYCONNECT-IKEV2-CESG general-attributes
 address-pool IPPOOL1
 default-group-policy ANYCONNECT-IKEV2-CESG
tunnel-group ANYCONNECT-IKEV2-CESG webvpn-attributes
 authentication certificate
Also, the default tunnel-group-map configuration is in place:
no tunnel-group-map enable rules
tunnel-group-map enable ou
tunnel-group-map enable ike-id
tunnel-group-map enable peer-ip
tunnel-group-map default-group DefaultRAGroup
I am connecting with the following client identity certificate:
CN= client1.domain.com
OU= ANYCONNECT-IKEV2-CESG
I figured that the default tunnel-group-map would take the OU of the client cert and map me to the relevant tunnel-group. Unfortunately, it looks like it lands on the DefaultRAGroup and I'm prompted for local authentication credentials.
If I configure the following certificate map, the connection lands on the correct tunnel-group:
crypto ca certificate map CERT-MAP 1
 subject-name attr ou eq anyconnect-ikev2-cesg
webvpn
 certificate-group-map CERT-MAP 1 ANYCONNECT-IKEV2-CESG
Any ideas as to why the connection doesn't follow the logic of the tunnel-group-map's OU matching?
Thank you,
Patrick
0 Replies 0
