Site-to-site VPN in packet tracer
joshbroadbent
I have configured two LANs with NAT. There is an ISP router inbetween these routers to emulate the internet.
I would like to configure a site-to-site VPN between these two routers.
Here is the configuration of R1 and R3:
R1:
  hostname R1
no ip cef
no ipv6 cef
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp key 0 address 209.123.123.33
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set yasser esp-aes esp-sha-hmac
crypto map auda 100 ipsec-isakmp
set peer 209.123.123.33
set pfs group2
set security-association lifetime seconds 86400
set transform-set yasser
match address ramzy
spanning-tree mode pvst
interface FastEthernet0/0
ip address 172.16.1.21 255.255.248.0
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.8.99 255.255.248.0
ip nat inside
interface Serial0/3/0
ip address 209.123.123.1 255.255.255.240
ip nat outside
clock rate 128000
crypto map auda
router ospf 1
router-id 15.15.15.15
log-adjacency-changes
network 172.16.8.0 0.0.7.255 area 1
network 209.123.123.0 0.0.0.15 area 0
ip nat inside source list ADDRESSES interface Serial0/3/0 overload
ip classless
ip flow-export version 9
ip access-list standard ADDRESSES
permit 172.16.8.0 0.0.7.255
ip access-list extended ramzy
permit ip 172.16.8.0 0.0.7.255 172.16.40.0 0.0.7.255
line con 0
line aux 0
line vty 0 4
login
end
R3:
hostname R3
no ip cef
no ipv6 cef
encr aes
group 2
crypto isakmp key 0 address 209.123.123.1
set peer 209.123.123.1
set pfs group2
match address ramzy
ip address 172.16.1.22 255.255.248.0
duplex auto
speed auto
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 172.16.40.99 255.255.248.0
ip nat inside
interface Serial0/3/1
ip address 209.123.123.33 255.255.255.240
ip nat outside
crypto map auda
router ospf 1
router-id 25.25.25.25
network 172.16.40.0 0.0.7.255 area 2
network 209.123.123.32 0.0.0.15 area 0
ip nat inside source list ADDRESSES interface Serial0/3/1 overload
ip classless
permit 172.16.40.0 0.0.7.255
permit ip 172.16.40.0 0.0.7.255 172.16.8.0 0.0.7.255
line con 0
line aux 0
line vty 0 4
login
end
Attempting to ping from PC-A (172.16.8.1) to PC-C (172.16.40.1) doesn't work.
I have tried numerous times to get traffic to flow through the tunnel with no succes. Can anyone tell me where I am going wrong?
Josh
Hi Josh,
On this deployment, you will not be able to ping or reach the other side because of the NAT, it is dynamically NATting the IP addresses, you will need to do the following:
R!:
no ip nat inside source list ADDRESSES interface Serial0/3/0 overload
no ip access-list standard ADDRESSES
ip access.list extended ADDRESSES_NAT
deny ip 172.16.8.0 0.0.7.255 172.16.40.0 0.0.7.255
ip nat inside source list ADDRESSES_NAT interface Serial0/3/0 overload
R3:
no ip nat inside source list ADDRESSES interface Serial0/3/1 overload
ip access-list extended ADDRESSES_NAT
deny ip 172.16.40.0 0.0.7.255 172.16.8.0 0.0.7.255
ip nat inside source list ADDRESSES:NAT interface Serial0/3/1 overload
with this show commands you make sure phase 1 and phase 2 is up and working::
- show crypto isakmp sa
- show crypto ipsec sa
Hope this helps!
Please proceed to rate and mark as correct the helpful Post!
David Castro,
Hi Josh,
R!:
R3:
Hope this helps!
David Castro,
joshbroadbent
Thanks for your help, David.
Much appreciated!
Josh Broadbent
Hi Josh,
It was a pleasure, let me know if you have any doubts!
David Castro,
