Uploading AA
CSCO11783236
Greetings, actually I do have a cisco router 2911, on this scenario I wanna add my AA message, I've downloaded this file from cisco website (CUE-AA-S1-OfficeHours-2.3.1.zip) and edit some parameters according to my requirement, my question now is how to upload this folder to the router and make it work? Should I've a special software or I can upload it normally to the flash using Standard CLI??
I tried to upload them using Cisco Configuration Professional App, but it didn't work.
please advise
Thanks in advance
Shadi Shami
Level 7
Level 7
Hello Mohammed,
You need CUE (Cisco Unity Express) module to be installed on the router to upload the file there, so do you have CUE module, you may check by typing (show inventory) on the router?
Thank you,
Shadi
thanks for your kind reply, i did not find this module, all what i found is:
Router# show inventory
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FTX1640AH7P, Hw        Revision: 1.0"
PID: CISCO2911/K9      , VID: V07 , SN: FTX1640AH7P
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot        0", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-1MFT-T1/E1  , VID: V01 , SN: FOC18208NPQ
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSl        ot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO=        , VID: V  , SN: FOC0942011G
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP D        IMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC18477T5R
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V05 , SN: ART1838F16U
plzzz advise how to implement this feature with this items????
