7960G Load Help!
spencerjohn
Friends,
I'm having a issue getting a phone to load the SCCP firmware.  I have one phone that loads the firmware and registers/calls out/in just fine but a second phone will not change from MGCP to SCCP.  For reference I'm running a 2651XM with CME (It goes through the loading process and gets to P0030801SR02.loads then restarts and the MGCP logo stays while it says configuring phone.  Here is my configuration excerpt, please let me know what I can do to get this phone working!
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server
voice register global
voice register dn  1
 number xxx
tftp-server flash:OS79XX.TXT
tftp-server flash:P0030801SR02.bin
tftp-server flash:P0030801SR02.loads
tftp-server flash:P0030801SR02.sbn
tftp-server flash:P0030801SR02.sb2
tftp-server flash:SEPDefault.cnf
tftp-server flash:P0030801SR02.txt
tftp-server flash:SEP0014A934058A.cnf
tftp-server flash:SEP0015F9A3B397.cnf  <--this is the phone that doesn't load
dial-peer voice 2 voip
 description **Outgoing Calls to SIP.US SIP Trunk**
 translation-profile outgoing SIP.US-Outgoing
 destination-pattern 1[2-9]..[2-9]......
 session protocol sipv2
 session target dns:gw1.sip.us
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711ulaw
 clid network-number xxx
 clid network-provided
 no vad
sip-ua
 credentials username xxx password xxx realm gw1.sip.us
 authentication username xxx password xxx
 retry invite 2
 retry register 10
 timers connect 100
 registrar dns:gw1.sip.us expires 360
telephony-service
 load 7960-7940 P0030801SR02
 max-ephones 4
 max-dn 4
 ip source-address 172.16.31.1 port 2000
 auto assign 1 to 2
 auto assign 1 to 10 type 7960
 auto assign 1 to 3
 system message welcome to xxx
 time-format 24
 create cnf-files version-stamp 7960 Apr 25 2015 18:21:13
 voicemail xxx
 max-conferences 4 gain -6
 web admin system name xxx password xxx
 dn-webedit
 time-webedit
 transfer-system full-consult
 directory entry 1 xxx name xxx
 xmltest
ephone-dn  1
 number xxx
 label xxx
 description xxx
 name xxx
ephone  2
 description phone 2
 mac-address 0014.A934.058A
 speed-dial 1 xxx
 speed-dial 2 xxx
 speed-dial 3 xxx
 speed-dial 4 xxx
 type 7960
 button  1:1
 pin xxx
ephone  3
 description xxx
 mac-address 0015.F9A3.B397
 speed-dial 1 xxx
 speed-dial 2 xxx
 speed-dial 3 xxx
 speed-dial 4 xxx
 type 7960
 button  1:1
 pin xxx
6 Replies 6
kkoeper12
Level 3
Level 3
I'm guessing you are trying to change the phone from SIP to SCCP since phones don't use MGCP firmware. Make sure there is no voice register pool defined for the MAC of the phone you are trying to convert. The put in these commands, unplug the phone and reboot it.
create profile
exit
telephony-service
no create cnf
create cnf
exit
Thanks for the reply!  I'll give it a shot when I can get to the phone later today.
Curious though...the phone has MGCP Config below the Network Settings and when I watch it on the router it's looking for MGCDefault.cnf and MGC[mac].cnf...
Either way, thanks and I'll give it a try!
john
MGCP is used between the router/gateway and CUCM (the other options are H.323 or SIP trunk). SIP or SCCP are the options for a phone to register with CUCM or CME.
If you are using CME without CUCM you can remove the MGCP commands, they aren't being used.
No dice.  Same result with the added commands.
I was able to fix the problem by manually inputting a windows TFTP server and flashing 7.6 SCCP firmware then reattaching to the UCM.  Everything working now!
john
Here is the debug as the phone tries to register:
Apr 27 19:43:23.684: TFTP: Looking for CTLSEP0015F9A3B397.tlv
Apr 27 19:43:23.708: TFTP: Looking for SEP0015F9A3B397.cnf.xml
Apr 27 19:43:23.744: TFTP: Looking for SIP0015F9A3B397.cnf
Apr 27 19:43:23.768: TFTP: Looking for MGC0015F9A3B397.cnf
Apr 27 19:43:23.788: TFTP: Looking for XMLDefault.cnf.xml
Apr 27 19:43:23.792: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 0, size 1129 for process 202
Apr 27 19:43:23.800: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 202
Apr 27 19:43:23.848: TFTP: Looking for P0030801SR02.loads
Apr 27 19:43:23.848: TFTP: Opened flash:P0030801SR02.loads, fd 0, size 458 for process 202
Apr 27 19:43:23.852: TFTP: Finished flash:P0030801SR02.loads, time 00:00:00 for process 202
Apr 27 19:43:32.650: TFTP: Looking for P0030801SR02.loads
Apr 27 19:43:32.654: TFTP: Opened flash:P0030801SR02.loads, fd 0, size 458 for process 202
Apr 27 19:43:32.658: TFTP: Finished flash:P0030801SR02.loads, time 00:00:00 for process 202
Apr 27 19:44:50.137: Skinny active socket list (1/285):  1
internet#
internet#
internet#
internet#
Apr 27 19:45:08.491: TFTP: Looking for MGCDefault.cnf
Apr 27 19:45:08.515: TFTP: Looking for MGC0015F9A3B397.cnf
Apr 27 19:45:09.962: TFTP: Looking for RINGLIST.DAT
Apr 27 19:45:09.970: TFTP: Looking for CARD.XML
