04-26-2015 06:14 PM - last edited on 03-25-2019 04:33 PM by ciscomoderator
hello
i configure C6880 with VSS,and use C6800IA with IA,which version is 15.2SY0a,i found a question,when C6800IA run alone without IA uplink to C6880,the command "ip device tracking" can be found and use,but when C6800IA link to C6880 with IA,and C6880 confiure VSS,the command "ip device tracking" can't found and no config,why?
08-19-2015 02:15 AM
I'm having the same issue. Any ideas?
Octavian
10-27-2015 06:53 AM
It seems that the command itself is not available from the CLI, but the feature seems to work just fine.
Octavian
08-23-2016 06:33 AM
Try using
"device-tracking"
not "ip device tracking"
Hope this helps
Ciao
JC
