04-27-2015 07:54 AM - edited 03-11-2019 10:50 PM
I've just unboxed my 5525-x and connected the management interface to the network. Gave it an ip address in the correct subnet but the interface does not come up.
logs show:
IKE port 10000 for IPSec UDP already reserved on interface management
How is the mangement interface configured for LAN access?
Ive also tried clear configure all. I just want the management interface connected so I can start configuring the firewall.
05-01-2015 10:10 PM
Hi Michael,
Could you please provide more detail on this.
1. ) What version are you running on ASA?
2.) Did clearing configuration resolved the issue?
3.) Try changing IP address on interface and see if it still generate this log.
4.) Could you please share the running-config from the ASA.
Thanks & Regards,
Akshay Rastogi
05-02-2015 06:41 AM
You said the interface is not up. Do you mean that literally - i.e. no link light? If so, please issue "no shut" in interface configuration mode.
Out of the box the management interface is at 192.168.1.1 and the ASA has a DHCP server assigning addresses to you from that /24 when you connect directly to the management port.
If you change the address, you need to make sure that you put the new subnet in the allowed management range for incoming ssh and http (ASDM) traffic.
I have no idea why you would be getting a log message related to IKE port 10000. That's not used for management in any direct way.
