04-28-2015 06:47 AM
I've a problem with the backup configuration file (CISCO RV042) . The result file (startup.config) isn't the actually configuration but the factory file?
04-28-2015 07:24 AM
Hello dviolant1,
Exactly what is the factory file you are referencing?
IOS?
The default backup file name is Startup.config, so the file name you referenced is the correct name.
Link below points to a knowledgebase for the RV042 router, which includes steps for backup and restore.
http://sbkb.cisco.com/CiscoSB/ukp.aspx?login=1&pid=2&app=search&vw=1&articleid=573&donelr=1
Hope this helps,
please rate helpful answers.
Thanks.
04-28-2015 07:52 AM
It's factory default CISCO
One step : configuration of the routeur CISCO
Two : Backup startup configuration ----> startup.config
Three : if 'restore startup configuration' with the startup.config file . I lose the actually configuration and i find the factory usine.
