04-28-2015 10:18 AM - edited 07-05-2021 03:04 AM
Cisco has released EOL announcement for the existing access points used in our organization (AIR-CAP3502I-A-K9)
Validate if Cisco AIR-CAP3702I-A-K9 can be used in our current hardware and software release.
If not, what needs to be upgraded.
04-28-2015 10:34 AM
What controller model and software are you on?
If you are on a Gen2 or better, 5508/8510/5760/2504/WiSM2, then you can run the code that supports the 3702.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80.html#pgfId-1218912
If you are on a Gen1 WLC, 440x/WiSM1/2106 then you would need to upgrade to a Gen2 controller to support the software.
HTH,
Steve
04-28-2015 12:21 PM
Hi Steve,
we have a 5500 series wireless controller & Model no is 5508.
Current SW version is 7.5.102.0.
And currently we have access points (AIR-CAP3502I-A-K9) Cisco has released EOL announcement for the existing access points.
And can we deploy Cisco AIR-CAP3702I-A-K9 can be used in our current hardware and software release.
04-28-2015 01:53 PM
yes the 5508 will support the 7.6 code, which you need to upgrade to so you can deploy the 3702 series access point.
HTH,
Steve
04-28-2015 10:39 AM
HTH,
Steve
