Cisco CWS with ISR G2 router issues
techguy
Level 4
Level 4
Hi everyone,
We are using Cisco CWS (evaluation version) connected with Cisco 2951 in UAE. Since, there is no tower in UAE and nearby, so we are advised to connect with CWS London tower.
Our web browsing experience is getting worse with the passage of time. Its very slow. when I disable CWS then browsing becomes fast.
Kindly advise. Thanks
kussriva
If you have configured the NTLM authentication and the ip admission command on the interface, try removing these and check if you still see the same issue.
Kush Srivastava
Cisco PDI TA
http://www.cisco.com/web/partners/tools/pdita.html
