04-29-2015 09:15 AM - edited 03-05-2019 01:22 AM
I have a port channel configured between a Cisco WS-C3850-48T and a Cisco Catalyst 2960-X Series switch. A couple of days ago two of the ports went down on the C3850 and I traced the problem to the SFP ports on the 2960. I tried plugging the cable into all four of those SPF ports (with the other end connected to the C3850) but the port light doesn't come on at all. I have eliminated the possibility of a bad cable or SFP transceiver because I can plug it into the SFP ports of other switches without an issue. Essentially, it looks like a hardware issue on the switch and I'm not sure how to handle it because unplugging everything from the switch and returning it isn't really a viable option.
Has anyone else had issues with SFP ports? And if so, how did you handle it?
04-29-2015 09:36 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
My experience either you replace the faulty equipment or you live with the broken port(s).
Of course, if you have a soldering iron, a logic analyzer, and don't mind voiding any still valid warranties, I guess you can try to repair it yourself. ;)
04-29-2015 09:40 AM
Haha. Thanks. Those do seem like the only two options but I was hoping for some magical cure because I don't like either one of them.
04-30-2015 06:19 PM
hi,
there's a professional kit to clean SFP and fibre optics but if you want a cheap fix, try to clean the SFP contacts (can also try to fibre optic cable tips) with a cotton swab/q-tip and damp of rubbing/isopropopyl alcohol.
05-01-2015 08:17 AM
Thanks. If the issue happens again I'll look in to doing that.
05-01-2015 12:08 PM
Hi rweir0001,
Before you assume the SFP ports are faulty, have you looked under the interface of the SFP ports.
It could be a spanning-tree or port security issue. This could be causing the ports to enter an err-disabled mode. This would explain why the ports work again after a switch reboot.
If you run into the same problem try running the following command(Note I am currently at home so have run the command from packet-tracer. But you will see a similar output)
Switch#sh interfaces gigabitEthernet 0/1
As you can see from the below it says "line protocol is down" then "(disabled)"
If you have a port violation this may say "(Err-disabled)" or on the newer 2960Xs some other helpful information.
GigabitEthernet0/1 is down, line protocol is down (disabled)
Hardware is Lance, address is 0001.63dd.ce19 (bia 0001.63dd.ce19)
MTU 1500 bytes, BW 1000000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Half-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:08, output 00:00:05, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
956 packets input, 193351 bytes, 0 no buffer
Received 956 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 0 multicast, 0 pause input
2357 packets output, 263570 bytes, 0 underruns
0 output errors, 0 collisions, 10 interface resets
0 lost carrier, 0 no carrier
If you are getting port violations, I would look at the show logging command and see what is causing the port to hit a violation.
Just my two cents woth!
HTH,
Kind Regards,
Liam
05-01-2015 12:23 PM
That's great advice, Liam, thanks! I'll take that into consideration if the problem resurfaces.
05-01-2015 12:38 PM
No problem at all! :) Also you mentioned you had the SFPs in a Port-Channel. So I would also look under the Po interface :)
Fingers crossed the problem doesn't re-surface.
Kind Regards,
Liam
05-01-2015 12:49 PM
Cool. Thanks.
04-30-2015 09:37 AM
I resolved the issue by reloading the affected 2960 switch and the SPF ports started functioning again.
