Web Security
Cisco CyberSecurity
Hello,A client is trying to SSH through the HTTP proxy (WSA), it works but the response times are huge.ssh_args = -C -o "ProxyCommand=nc -X connect -x proxy-http:8080 %h %p"It serves its purpose. HTTP proxy isn't designed for that, but has anyone tri...
cisco.13 by Level 1
  • 159 Views
  • 5 replies
Hi Folks i have a doubt we have Cisco data security services enabled for upload inspection in our WSA and in that policy we have one URL custom category as passthrough and one identification profile is also configured and upload limit is 500 mb .so t...
SIB9 by Level 1
  • 126 Views
  • 2 replies
Resolved! Virtual WSA sizing
Hi,   Anyone able to guide through a few sizing numbers for S300v/S600v/S1000v?   Currently under an incident that the 4 x S300v keeps crashing under a certain load and TAC believes it is the loading issue.  However, they don't follow up with the rec...
svenus by Level 1
  • 127 Views
  • 1 replies
I have one question that is the number of users in the license mean the total number of WSA appliances that will apply license to them or the number of clients connected to WSA appliances, because I will use one WSA appliance in the networkLicense WS...
osama1975 by Level 1
  • 132 Views
  • 1 replies
Hello,I don't understand how can I use transparent mode using L4 switch (it's load-balancer, right?). I'm friendly with L4 switches, even though I can not imagine the topology and data flow. I have two WSA boxes and I need configure active-backup mod...
Hi, currently we are using umbrella roaming clients across 3000 roaming user laptops. Now we need to upgrade the client to Cisco Secure Client.How the bulk upgrades can be done across roaming user laptops
manvik by Level 3
  • 313 Views
  • 4 replies
Hi guys,I have two servers on the same subnet which test curl a destination (cisco.com) via the WSA Proxy.The first one works correctly and I see in the logs:TCP_MISS/200 93202 CONNECT tunnel://www.cisco.com:443/=> CONNECTThe second one does not work...
cisco.13 by Level 1
  • 242 Views
  • 1 replies
Hi,I encountered an issue when attempting to access my website. I received an alert from Cisco Umbrella stating that "this site is blocked due to a phishing threat."I do not use Cisco Umbrella services. Why am I seeing this alert?Why has Cisco flagge...
Top Solution Authors
