how to configure WPA-PSK [TKIP] aironet 2700
kenier
We have a AP 2700 and we are using wpa2-psk (AES) but must of the client are having disconnection problems.
And we would like to test WPA-PSK [TKIP] . Here is he current config.
version 15.3
no service pad
service password-encryption
hostname Office
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone -0500 -5 0
clock summer-time -0400 recurring
no ip source-route
no ip cef
ip domain name naranjo.com
ip name-server 8.8.8.8
ip name-server 4.2.2.2
dot11 syslog
dot11 ssid CIP2.4Ghz
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 132348071F0409232A292164657243
dot11 ssid CIP5.0Ghz
   vlan 1
   authentication open
   guest-mode
   wpa-psk ascii 7 10AC460C333F1F020D09237C747863
username
ip ssh authentication-retries 5
bridge irb
interface Dot11Radio0
 no ip address
 encryption vlan 1 mode ciphers aes-ccm
 ssid CIP2.4Ghz
 antenna gain 0
 stbc
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 ssid CIP5.0Ghz
 antenna gain 0
 peakdetect
 dfs band 3 block
 stbc
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss7 a2ss7 a3ss7
 channel dfs
 station-role root
interface Dot11Radio1.1
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0.1
 bridge-group 1
interface GigabitEthernet1
 no ip address
 shutdown
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address f07f.062f.e124
 ip address 192.168.1.10 255.255.255.0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community defaultCommunity RW
access-list 111 permit tcp any any neq telnet
bridge 1 route ip
line con 0
 access-class 111 in
line vty 0 4
 access-class 111 in
 length 0
 transport input all
sntp server us.pool.ntp.org
sntp broadcast client
end
_________________________________________________
thanks in advance.
Stephen Rodriguez
honestly, if the clients connect in the first place, I wouldn't think it was an encryption issue, more of a coverage issue.
And I wouldn't do a separate SSID for 2.4 and 5GHz, you should just have SSID for both radios.
You could be having an issue of the client being on 5GHz and having it's signal be too low, and it attempts to move to 2.4GHz but the client has to switch SSID which can cause you some weird issues.
So first thing I would try is consolidating to one SSID, and checking the signal of the 5GHz radio in your areas.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Here is the log with some errors. The distance between the farthest room is less than 25. It only have one door in the middle.
ndex Time Severity Description
1 Apr 30 17:17:36.844 Information Interface Dot11Radio1, Deauthenticating Station 4c8d.79d5.fe78 Reason: Class 2 frame received from nonauthenticated station
2 Apr 30 17:15:45.963 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
3 Apr 30 17:15:45.951 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
4 Apr 30 17:15:43.832 Notification Line protocol on Interface Dot11Radio1, changed state to up
5 Apr 30 17:15:42.832 Information Interface Dot11Radio1, changed state to up
6 Apr 30 17:15:37.655 Notification Line protocol on Interface Dot11Radio1, changed state to down
7 Apr 30 17:15:36.315 Notification Interface Dot11Radio1, changed state to resetPCI reset port 1
8 Apr 30 17:15:36.291 Information Error on Dot11Radio1 -
9 Apr 30 17:13:27.295 Information Interface Dot11Radio1, Station 4c8d.79d5.fe78 Reassociated KEY_MGMT[WPAv2 PSK]
10 Apr 30 17:13:27.283 Information Interface Dot11Radio1, Deauthenticating Station 4c8d.79d5.fe78 Reason: Sending station has left the BSS
11 Apr 30 17:13:25.271 Notification Line protocol on Interface Dot11Radio1, changed state to up
12 Apr 30 17:13:24.315 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
13 Apr 30 17:13:24.303 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
14 Apr 30 17:13:24.271 Information Interface Dot11Radio1, changed state to up
15 Apr 30 17:13:20.007 Notification Line protocol on Interface Dot11Radio1, changed state to down
16 Apr 30 17:13:18.667 Notification Interface Dot11Radio1, changed state to resetPCI reset port 1
17 Apr 30 17:13:18.643 Information Error on Dot11Radio1 -
18 Apr 30 17:10:16.549 Information Interface Dot11Radio1, Station 4c8d.79d5.fe78 Reassociated KEY_MGMT[WPAv2 PSK]
19 Apr 30 17:10:10.396 Information Interface Dot11Radio1, Deauthenticating Station 4c8d.79d5.fe78 Reason: Class 2 frame received from nonauthenticated station
20 Apr 30 17:09:05.864 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
21 Apr 30 17:09:05.852 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
22 Apr 30 17:09:03.645 Notification Line protocol on Interface Dot11Radio1, changed state to up
23 Apr 30 17:09:02.645 Information Interface Dot11Radio1, changed state to up
24 Apr 30 17:08:57.525 Notification Line protocol on Interface Dot11Radio1, changed state to down
25 Apr 30 17:08:56.185 Notification Interface Dot11Radio1, changed state to resetPCI reset port 1
26 Apr 30 17:08:56.161 Information Error on Dot11Radio1 -
27 Apr 30 17:07:21.307 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
28 Apr 30 17:07:21.295 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
29 Apr 30 17:07:19.159 Notification Line protocol on Interface Dot11Radio1, changed state to up
