05-01-2015 04:44 AM - edited 03-18-2019 04:25 AM
Any help is appreciated .
1. Can I get a voice prompt to tell a only participant customer they are in the call???
2. Is there hold music capability for the only participant in the room??
We have codian 4500 and 4200 series MCU's ???
Thanks.
Solved! Go to Solution.
05-02-2015 07:15 AM
The two settings are listed in my first reply.
05-01-2015 02:58 PM
I know if you join an empty conference on an MCU, you'll get an audio prompt, you can also provide a message saying they are the only participant.
Settings > Conferences
MCUs don't have any hold music feature.
05-02-2015 02:29 AM
Thank you for the heads up ... I did upload the Audio Package from the TANDBERG FTP site.
No change. Looks like the First Participant .wav file isn't enabled??
What setting would enable it???
Thanks.
Oh and I am running software version 4.5 on the 4520.
05-02-2015 07:15 AM
