Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919080members
1223087discussions
Community Activity
Poor 5Ghz throughput - 9800 / 17.9.4a / 1800-series APs
Hi,Per the title, I've got an issue with 5Ghz clients that have good signal strength because they are sat almost underneath the AP (1832 APs) yet but struggling to get more than 1Mbps throughput.  I can see the channel utilisation is over 50% but zer...
Cisco AnyConnect requires Reboot to connect second time
On my Windows 10 computer, I can connect to the VPN using AnyConnect 3.1.02026 without difficulty. However, once I disconnect, I need to reboot my computer to connect again. When I try to connect the second (and subsequent) times I get the message, "...
richards by Level 1
  • 25376 Views
  • 18 replies
9800-L WLC Controller and CA Signed Cert Web Server
Does anyone have a Cisco 9800-L WLC Controller and successful installed a CA Signed Cert for Web Server? Not making the Certificate signing request, but actually already have the PEM and other files locally. Cisco TAC can't figure it out. The documen...
Migrating IPSec tunnel
Hello,I have a question about migrating a IPSec tunnel from between a Cisco C981F-k9 and a Cisco ASA firewall to a tunnel from the same Cisco C981F-k9 router to a Fortigate firewall. What is the 'best' way to migrate this tunnel?Currently I have conf...
MBestt by Level 1
  • 27 Views
  • 0 replies
NetFlow Lite (2960X) sampler
Dear community I am getting into NetFlow a little bit deeper but cannot get my head around sampling. All i understand so far: We can configure deterministic sampling, that uses a hardware sampler per interface, limiting the maximum number of monitori...
Resolved! Access Point
Hi all, can the cisco catalyst AP model 9136I, act as Autonomous.
CISCO C1111-4P software upgrade path
I have a C1111-4P router with c1100-universalk9.17.06.01a.SPA.bin image loaded, I want to update to c1100 universalk9.17.13.01a.SPA.So can I update directly to a new image or need to update any intermediate?
fti-it by Level 1
  • 96 Views
  • 2 replies
