05-06-2015 10:28 PM - edited 03-07-2019 11:54 PM
I have a pair of Catalyst 6500 Switch which supports Layer 2 and Layer 3 functionality. We have SVI created for vlans let's say vlan 4, vlan 5 on these 6500 Switches. Now i want to migrate these SVI over to Nexus 7K Switch.Please note the Catalyst 6500 and Nexus 7K are connected with Single sided VPC ? But N7K already has SVI for vlan 4 and vlan 5.So i cann't simply just migrate these SVI to Nexus 7k from Catalyst 6500.
So i want to Migrate vlan 4 in Cat 6500 as vlan 1004 in Nexus 7k and vlan 5 in Cat 6500 as vlan 1005 in Nexus 7K.
So what i did was: we created a BVI on Catalyst 6500 and configure the bridge-group but still i am not able to ping the host connected to 7K with vlan 1004.
This is what i configured on Catalyst 6500
interface Vlan4
ip address 192.168.75.1 255.255.255.0
bridge-group 1
interface Vlan1004
ip address 192.168.76.1 255.255.255.0
bridge-group 1
bridge 1 protocol vlan-bridge
bridge 1 priority 8192
One host is in Vlan 4 and connected to Cat 6500 side and other host is in vlan 1004 and connected to Nexus 7K. Is there anyway i can make this work so that host in vlan 4 on Catalyst 6500 side can communicate with the host in vlan 1004 on Nexus side.
Please let me kknow if you have already done this or encountered this issue.
05-06-2015 11:32 PM
Why not stick with VLAN 4 on the N7K and migrate SVI's as normal. You can use secondary address on the svi.
I don't think there is a need for VL1004 if hosts need to communicate with each other in both VLANs
hth
Bilal
05-07-2015 08:48 AM
Hi Bilal,
I understand what you are saying but SVI for vlan 4 already exists on N7K which already has few secondary ip addresses so i don't want to make even bigger broadcast domain by adding another secondary ip address.
05-07-2015 12:35 PM
How are they tied together ? You can't just trunk those vlans between the boxes ? Or are you running a routing protocol between those 2 boxes ?
