05-07-2015 06:40 PM - edited 03-11-2019 10:54 PM
Hi Expert,
Recently came across one issue on client that every time ASA reboots, SSH will not work.
It looks very likely that private key seems corrupted as I have to zeroize the old key and regenerate a new one, any idea why this is happening?
SSH session from x.x.x.x on interface outside for user "" disconnected by SSH server, reason: "Internal error" (0x00)
Jack
05-09-2015 03:21 AM
I think this might be related to the corrupt flash otherwise i don't think this should be corrupting the keys after the reloading of the ASA device.
Try an fsck flash and see if that throws any errors ?
Thanks and Regards,
Vibhor Amrodia
05-10-2015 06:29 PM
Actually, this was what I didn't figure out, why I can't seems to find any key under flash/disk0? is this by design that the key can't be easily found?
05-09-2015 06:39 AM
I seem to recall a bug around this issue. What version of ASA software are you running?
05-10-2015 06:20 PM
8.2.5, without any interim hotfix
05-10-2015 09:15 PM
Can you verify you have
aaa authentication ssh console LOCAL
...set?
You might also try "debug ip ssh" and/or also look at a packet trace from your client when trying to connect. They may give a more useful and precise error message.
Re your other question - yes the RSA key is not shown in a filesystem directory.
