05-08-2015 07:44 AM - edited 03-18-2019 04:27 AM
During instal of several new endpoints of type MX & SX I noticed broken/bad cables for connecting the touch panels. I'm referring to the grey flat-type UTP cables. I know they can easily be replaced by a standard UTP cable.
Anyone got the same problem with these cables?
Is there any place on Cisco website where I can report this?
05-08-2015 09:55 AM
If they are new endpoints, and you have an active support contract, I'd open a TAC case and get replacements. Or, like you said, you can use a standard UTP cable, which is what I'm using for one of our touch panels.
05-08-2015 09:41 PM
Yep have come across bad ones as well, but generally they stop working soon after installation for no apparent reason. Replace with standard cables and it solves the problem and saves it from just happening again with a replacement from TAC.
05-10-2015 10:53 PM
Looks to me there's a quality issue. Which channel within Cisco should I use to report this?
When you install a new system you have no time to wait for Cisco to provide a spare. If I recall well for new products there is a spare part delivery delay of 10 working days...
rgds, Geert Folens.
05-11-2015 08:50 AM
Yes, every second installation I have at least one failing cable.
They are pretty naughty, since most of the time, the touch is booting but then hanging. Swapping the cable with the shorter/longer one fixes it immediately.
The solution to open a tac case for such a simple issue is pretty ridiculous. It hurts your ratio and it is just a lot of work for a simple cable.
It leaves a certain feeling at the end of the installation about the overall quality.
Danny
