05-08-2015 11:15 PM - edited 03-13-2019 08:57 PM
We are planning to revamp the Network infrastructure in our organization . Find the attached existing setup of the Infrastructure.we want following services over the WAN .Kindly suggest the Cisco solution for the same.
1) Load balancing & Failover between two MPLS links
2) MPLS Link Optimzaion
3) Internet traffic of the branch office should be pass through HO
4) Applied QoS on to pass voice and video traffic over the WAN
5) Centralized WLAN infrastructure
6) Applications to be access from HO are E-mails,ERP,Voice & Video.
05-12-2015 12:40 AM
Qus not clear. What is your expectation ?
Do you need HW model suggestion or config suggestions ?? or anything else ?
05-16-2015 07:08 AM
Hi Vivek I need solution with HW models to suffice the requirements.Consider 100 users at the HO and 20 users on each site.
Actually I am getting confuse how to achieve Load balancing & optimization over MPLS links from 2 different ISPs ?
I hope you have clarity now.
05-31-2015 11:07 AM
Posts in this discussion have been removed due to possible misconduct. Please refer to the CSC terms of use for more details. https://supportforums.cisco.com/document/29951/cisco-support-community-acceptable-use-agreement
The Cisco Support Community
