05-09-2015 11:58 AM
Hello everyone
I am trying to make a simple test for multicast over MPLS Traffic-Engineering P2MP tunnels for IOS XR. I am using XRV for this test and as far as I can see the control plane works alright. The tunnel comes up the the correspoding MPLS labels are destributed in the test topology.
But I have not been able to test this with multicast traffic (to verify that traffic is flowing from head-end to receivers). For this I am using ping to send multicast packets from router R6 => R2, R1. I have not been successful and my attempts to find the cause of the problem have not been fruitful.
I was wondering if anyone has successfully test multicast over MPLS Traffic-Engineering P2MP tunnels in XRV (Is this feature supported in XRV in the first place?)
Specifically the multicast traffic does not seem to enter the tunnel (much more leave the router):
RP/0/0/CPU0:R6#sh mfib interface tunnel-mte 126
Sat May 9 19:23:38.276 UTC
Interface : tunnel-mte126 (Enabled)
SW Mcast pkts in : 0, SW Mcast pkts out : 2814 <<<<===
TTL Threshold : 0
Ref Count : 5
RP/0/0/CPU0:R6#sh interfaces tunnel-mte 126
Sat May 9 19:27:47.049 UTC
tunnel-mte126 is up, line protocol is up
Interface state transitions: 13
Hardware is Tunnel-MTE
Internet address is 6.6.6.6/32
MTU 1500 bytes, BW 0 Kbit
reliability 255/255, txload Unknown, rxload Unknown
Encapsulation TUNNEL, loopback not set,
Last input never, output never
5 minute output rate 0 bits/sec, 0 packets/sec <<<<===
0 packets input, 0 bytes, 0 total input drops
0 drops for unrecognized upper-level protocol
Received 0 broadcast packets, 0 multicast packets
0 packets output, 0 bytes, 0 total output drops
Output 0 broadcast packets, 0 multicast packets
RP/0/0/CPU0:R6#sh mfib route 232.0.0.1
Sat May 9 19:28:07.067 UTC
Failure Counts: RPF / TTL / Empty Olist / Encap RL / Other
(192.168.60.254,232.0.0.1), Flags:
Up: 1d03h
Last Used: never
SW Forwarding Counts: 0/0/0
SW Replication Counts: 0/0/0
SW Failure Counts: 0/0/0/0/0
tunnel-mte126 Flags: NS EG LVIF, Up:23:37:39
GigabitEthernet0/0/0/0.60 Flags: A, Up:1d03h
Is this an XRV limitation or should I continue try to find the error?
05-15-2015 11:38 AM
I am joining to question. But at first I am interested BGP mvpn session.
I have success working NG-MVPN (P2MP signalled RSVP-TE) on juniper devices M-series.
I joined IOSv PE to the working topology. On cisco PE I turned on ipv4 mvpn family and A-D and C-multicast routes had been success recieved from members of multicast VPN
Routes type 1 - received
Route Distinguisher: 10.95.95.52:1 (default for vrf mvpn-tm-pe)
*>i [1][10.95.95.52:1][10.94.94.1]/12
10.95.95.1 100 0 i
*>i [1][10.95.95.52:1][10.94.94.31]/12
10.95.95.31 100 0 i
*>i [1][10.95.95.52:1][10.94.94.38]/12
10.95.95.38 100 0 i
*>i [1][10.95.95.52:1][10.94.94.42]/12
10.95.95.42 100 0 i
*>i [1][10.95.95.52:1][10.95.95.43]/12
10.95.95.43 100 0 i
Routes other types are also received.
But Cisco PE doesn't advertise even A-D route Type-1 as member this VPN.
Then I tried on XRv. 2 PE joined each other.
Config one of PE's
hostname XR6
explicit-path name to5
index 1 next-address strict ipv4 unicast 1.1.1.5
vrf A
vpn id 1:1
address-family ipv4 unicast
import route-target
1:1
export route-target
1:1
address-family ipv4 multicast
interface Loopback0
ipv4 address 6.6.6.6 255.255.255.255
interface Loopback1
vrf A
ipv4 address 172.16.0.6 255.255.255.255
interface tunnel-mte1
ipv4 unnumbered Loopback0
destination 1.1.1.5
path-option 1 explicit name to5
signalled-bandwidth 1000
interface MgmtEth0/0/CPU0/0
shutdown
interface GigabitEthernet0/0/0/0
ipv4 address 1.1.1.6 255.255.255.0
route-policy rpf
set core-tree p2mp-te
end-policy
route-policy pim-to-bgp
if destination in (5.5.5.5/32) then
set c-multicast-routing bgp
endif
end-policy
router isis 1
is-type level-2-only
net 49.0000.0000.0006.00
metric-style wide
mpls traffic-eng level-2-only
mpls traffic-eng router-id Loopback0
mpls traffic-eng multicast-intact
interface Loopback0
passive
router bgp 1
bgp router-id 6.6.6.6
network 6.6.6.6/32
address-family vpnv4 unicast
address-family ipv4 mvpn
retain route-target all
address-family vpnv4 multicast
neighbor 5.5.5.5
remote-as 1
update-source Loopback0
vrf A
rd 1:6
bgp router-id 172.16.0.6
network 172.16.0.6/32
rsvp
bandwidth
mpls traffic-eng
mpls ldp
address-family ipv4
multicast-routing
address-family ipv4
enable
mdt source Loopback0
core-tree-protocol rsvp-te
bgp auto-discovery p2mp-te
leaf-info-required
mdt static p2mp-te tunnel-mte1
vrf A
address-family ipv4
interface Loopback1
enable
segmented
leaf-info-required
router igmp
vrf A
interface Loopback1
join-group 239.59.0.1
router pim
address-family ipv4
mdt data announce-interval 3
enable
vrf A
address-family ipv4
rpf topology route-policy rpf
mdt c-multicast-routing bgp
unicast-reachability source-as enable
rp-address 172.16.0.6
interface Loopback1
enable
end
I got the same result. No advertise even 1-type routes.
Experts like Luc de Gein we are waiting your answer.
05-27-2015 06:53 AM
There is a fix so the control-plane is working for the mVPN, I tested several profiles but the forwarding is not supported.
Maybe in XRv 9000 they will have full forwarding capabilities also for mVPN.
05-27-2015 09:33 PM
Hello
I have even not working control plane between 2 XRv. No any AD routes. Show me your config and issue "show bgp ipv4 mvpn summ" pls
05-28-2015 02:23 AM
Hey,
You need a SMU for this to work.
I any case I'll recommend to use SSM if you plan to put this in production, for learning purposes is ok.
There are a few wrong or missing parts in your configuration.
I have a running topology with profile 26 Partitioned MDT - P2MP TE - BGP-AD - BGP C-mcast signaling not very different from your profile 18 default Static MDT - P2MP TE - BGP-AD - PIM C-mcast signaling.
Here are some relevant parts of the config
RP/0/RSP0/CPU0:PE01#sh run multicast-routing
Thu May 28 01:10:10.348 UTC
multicast-routing
address-family ipv4
interface Loopback0
enable
interface Loopback1
enable
ssm range SSM-MDT
vrf vrf1
address-family ipv4
interface GigabitEthernet0/0/0/2
enable
mdt source Loopback1
ssm range C-MULTICAST
rate-per-route
accounting per-prefix
leaf-info-required
mdt partitioned p2mp-te attribute-set VRF1
RP/0/RSP0/CPU0:PE01#sh run router pim
Thu May 28 01:10:31.333 UTC
router pim
address-family ipv4
interface Loopback0
enable
interface Loopback1
enable
vrf vrf1
address-family ipv4
rpf topology route-policy P2MP-TE-PARTITIONED
enable
RP/0/RSP0/CPU0:PE01#sh run mpls traffic-eng
Thu May 28 01:10:40.535 UTC
mpls traffic-eng
interface GigabitEthernet0/0/0/1
logging events preemption
logging events frr-protection
auto-tunnel p2mp
tunnel-id min 1000 max 2000
auto-tunnel backup
timers removal unused 20
tunnel-id min 5000 max 6000
reoptimize 1
attribute-set p2mp-te VRF1
logging events lsp-status reoptimize
logging events lsp-status reroute
logging events lsp-status bw-change
logging events lsp-status insufficient-bandwidth
signalled-bandwidth 10000 class-type 0
fast-reroute
RP/0/RSP0/CPU0:PE01#sh run ipv4 unnumbered mpls traffic-eng
Thu May 28 01:11:47.214 UTC
ipv4 unnumbered mpls traffic-eng Loopback1
RP/0/RSP0/CPU0:PE01#sh run router bgp
Thu May 28 01:13:32.744 UTC
router bgp 12345
bgp router-id 192.168.0.10
additional-paths receive
network 192.168.1.10/32 route-policy RPL-PE-MVPN
allocate-label route-policy RPL-ALLOCATE-LABEL-LBGP
address-family ipv4 mdt
address-family l2vpn vpls-vpws
neighbor-group PE-RR-VPN
remote-as 12345
update-source Loopback1
neighbor-group DR-RR-IPV4
remote-as 12345
neighbor-group DR-RR-LBGP
remote-as 12345
update-source Loopback2
address-family ipv4 labeled-unicast
route-policy RPL-DR-RR-LBGP-IN in
route-policy RPL-DR-RR-LBGP-OUT out
neighbor 192.168.0.9
use neighbor-group DR-RR-IPV4
neighbor 192.168.1.9
use neighbor-group PE-RR-VPN
neighbor 192.168.2.9
use neighbor-group DR-RR-LBGP
vrf vrf1
rd 1:1
redistribute connected
redistribute static
05-28-2015 03:46 AM
let me issie "show bgp ipv4 mvpn su" pls
and show advertise mvpn routes pls
05-28-2015 04:09 AM
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1:1 (default for vrf vrf1)
*>i[1][192.168.1.1]/40
192.168.1.1 100 0 i
*> [1][192.168.1.10]/40
0.0.0.0 0 i
*>i[3][0][0.0.0.0][0][0.0.0.0][192.168.1.1]/120
192.168.1.1 100 0 i
*> [3][0][0.0.0.0][0][0.0.0.0][192.168.1.10]/120
0.0.0.0 0 i
*>i[4][3][1:1][0][0.0.0.0][0][0.0.0.0][192.168.1.10][192.168.1.1]/224
192.168.1.1 100 0 i
*>i[7][1:1][16422][32][192.168.232.46][32][233.232.0.14]/184
192.168.1.1 100 0 i
05-28-2015 04:22 AM
Is it configuration on XRv or on real XR?
05-28-2015 04:27 AM
XRv, on hardware box the forwarding works but on XRv not.
05-28-2015 05:05 AM
I understood. Type me in PM your skype
