05-12-2015 02:52 PM - edited 03-10-2019 12:25 AM
I need to download Cisco Secure Desktop, and I followed the link provided below from cisco... but it gave forwarded me to a different link.
http://www.cisco.com/c/en/us/td/docs/security/csd/csd34/configuration/guide/csd34cfg/CSDinstl.html
http://www.cisco.com/cgi-bin/tablebuild.pl/securedesktop
Help please!
Solved! Go to Solution.
05-29-2015 02:49 PM
If you found the information helpful, please, mark it as correct answer.
Thanks.
05-20-2015 09:53 AM
Hello keonis1316,
Unfortunately, CSD is deprecated and this images are not longer available in the Cisco Webpage; however, Hostscan or the "posture assessment" is still available. You can download the latest hostscan from the Cisco webpage.
You can also refer the following links for further information.
- Feature Deprecation Notice for Secure Desktop (Vault), Cache Cleaner, Keystroke Logger Detection, and Host Emulation Detection
- Installing and Enabling Host Scan on the ASA
Hope this helps
05-29-2015 02:05 PM
Thanks!
05-29-2015 02:49 PM
Thanks.
