ATA 190 and CME 10.5
adolfocgx
Hi guys can someone show me and example of the "fast track" configuration needed to setup an ATA190 in CME 10.5? or post a working example with this ATA 190 and CME?
6 Replies 6
Manish Gogna
To deploy Cisco Unified SIP IP phones on Cisco Unified CME using the fast-track configuration approach, you require Cisco IOS Release 15.3(3)M or a later release.
To support Fast-Track Configuration feature, the voice register pool-type command has been introduced in the global configuration mode. The properties of the new SIP phone can be configured under the voice register pool-type submode. In addition to the explicit configuration of the phone’s properties, the reference-pooltype option can be used to inherit the properties of an existing SIP phone.
Check the section "SIP: Provisioning Using the Fast-Track Configuration Approach"
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#50575
Manish
I´ve followed that instructions but the CME does not create the "ATADBFD18720801.cnf.xml" file,
this is my config
voice register pool-type  ATA190
 reference-pooltype ATA-187
voice register global
 mode  cme
 source-address 10.10.14.1 port 5060
 timeouts interdigit 5
 max-dn 200
 max-pool 30
 load 8831 sip8831.10-3-1-16.loads
 timezone 9
 mwi reg-e164
 voicemail 30648
 tftp-path flash:
 create profile sync 0002053712944464
 network-locale ES
 user-locale ES
 conference hardware
voice register pool  24
 busy-trigger-per-button 2
 id mac 34DB.FD18.7208
 type ATA190
 number 1 dn 24
 cor incoming call-Local default
 dtmf-relay rtp-nte sip-kpml sip-notify
 username 30624 password 30624
 no vad
**the tftp debug shows this:
*May 18 21:27:42.943: TFTP: Looking for ATA34DBFD187208.cnf.xml
*May 18 21:27:42.943: TFTP: Sending error 1 No such file
and I runned a sh flash | inc .xml, all the oher phones files are there, but the ATA file is not, actually it shows as a SEP and not as a ATA.
SEP34DBFD187208.cnf.xml
any ideas?
I'd this problem on a Cisco 2921.It's a bug, fix is to upgrade to IOS c2900-universalk9-mz.SPA.155-2.T.bin. The bug is internal to Cisco so I don't have a bug id.
Once I upgraded I went into "voice register global" and "create profile". ATA Config file is now ATA34DBFD186700.cnf.xml, it was SEP34DBFD186700.cnf.xml previously.
voice register pool-type  ATA-190
 no phoneload-support
voice register dn  4
 number 2404
 allow watch
 name 2404
 label 2404
voice register pool  4
 id mac 34DB.FD18.6700
 type ATA-190
 number 1 dn 4
 username 2404 password 2404
 codec g711ulaw
Here is the bug id, however I don't have permissions to view it.
CSCus55079: ATA-190 does not create configuration file with prefix "ATA
Yes seems you are hitting this BUG. upgrade.
Br, Nadeem Please rate all useful post.
I have a question, how many memory RAM has in your Router?, 512 MB or 1GB?
Regards...
