05-15-2015 05:49 PM - last edited on 03-25-2019 03:44 PM by ciscomoderator
Quick question:
Since upgrading our WAN router from a 7204VXR to an ASR1002X we have come across the IP multicast-routing command wanting a further option to complete !
The options are 1. Distributed or 2. VRF
If we want to continue in our previous configuration on the 7200 router what option is required ?
I'm guessing "distributed" but can someone ratify this for me please.
Solved! Go to Solution.
05-15-2015 06:03 PM
Yes, that is correct. You just need "distributed". VRF option is for when the device is running VRFs.
05-15-2015 06:03 PM
