What is it you're trying to edit. If you have SSH access to the E20, you could use the API to make configuration changes as well as control the E20. Here is the E20 Admin Guide for the configuration options. If you log into the E20 using SSH with the admin account, you can see a list of the configuration and command that you can use by typing in either these:
xConfiguration ?
xCommand ?
Learn, share, save
