05-17-2015 12:25 PM
Can the built in 10GE ports on the RSP440 be used as regular 10GE ports, or are these locked as nV cluster ports?
Solved! Go to Solution.
05-18-2015 12:47 AM
05-19-2015 04:31 AM
Florian is correct, these ports can only be used for nV Edge.
These ports do not act like normal ethernet ports and they cannot be configured, for instance you cannot go under mpls ldp or router isis and add these control links.
Sam
05-18-2015 12:47 AM
They can only be used as NV ports.
Florian
05-19-2015 04:31 AM
Sam
