05-19-2015 06:41 AM
Hey guys
Is it possible to have the ASR 9010 send out an SNMP trap when a power supply fails or is it only possible to query for this even using SNMP?
Gr,
Tom
05-19-2015 11:06 AM
yeah that is part of the ENTITY-MIB Tom. you would need to enable the "sysowner" keyword however for monitoring power supplies on the community definition.
see more info here:
https://supportforums.cisco.com/document/86836/asr9000-monitoring-power-supply-information-snmp
xander
05-20-2015 01:10 AM
Hey Xander
I saw and read your post on Monitoring Power Supply Information via SNMP on the ASR9k, but I did not find anything about the ASR sending traps. It looked to me this was only for the NMS to poll the ASR for their power supplies. We currently have the following commands in place (among others) but we did not receive an SNMP trap when the power supply failed.
snmp-server community CISCO RO SystemOwner ASR9k
snmp-server traps system
snmp-server traps sensor
Tom
05-20-2015 04:54 AM
hi tom! you may be running into :
CSCue79000 YJFT: Fru Traps not raised when Fan Tray or Power Shelf is OIR'ed
cheers
xander
05-21-2015 04:17 AM
Hi Xander
This indeed seems to be the case. I was, however, only able to find this bug for release 4.3.1 while we are still running version 4.2.3. I created a TAC to further have it investigated.
Thank you for your support!
Best regards
Tom
05-22-2015 07:31 AM
Apparently I need snmp-server traps fru-ctrl and not system or sensor. It's not a bug after all.
05-22-2015 08:09 AM
that's always good :) thanks for the confirmation and closure on this Tom!
xander
