ASA-SM upgrade to 9.4.1 "WARNING: Failover is enabled but standby IP address is not configured for this interface" errors
Darren Cooper
I have ASA-SM pair (WS-SVC-ASA-SM1) in active/standby failover mode currently running 9.0.4  (asa904-smp-k8)
I am upgrading to 9.4.1 and first attempt failed giving the following errors for every interface on every context when reloading the standby:
*** Output from config line 704, "admin-context admin"
WARNING: Failover is enabled but standby IP address is not configured for this interface.
*** Output from config line 23, context 'admin', " ip address 192.168.100...."
*** Output from config line 28, context 'admin', " ip address 192.168.62...."
Cryptochecksum (unchanged): 001694fe 4f35b7e7 3a89fcb6 396e8984
*** Output from config line 718, "  config-url disk0:/admi..."
Creating context 'rtman'... Done. (2)
*** Output from config line 721, "context rtman"
.WARNING: Failover is enabled but standby IP address is not configured for this interface.
*** Output from config line 25, context 'rtman', " ip address 192.168.129...."
The config is then replicated from the active with the same issue:
************WARNING****WARNING****WARNING********************************
   Mate version 9.0(4) is not identical with ours 9.4(1)
Type help or '?' for a list of available commands.
ASA-Model> .
        Detected an Active mate
#Beginning configuration replication from mate.
Each context configuration has the correct interfaces so why is it being rejected? The post 9.4.1 config is identical to the 9.0.4 version bar a couple of SSH commands.
Any ideas please?
Darren
Vibhor Amrodia
This is only an informational message that the DATA interface does not have a standby IP configured.
This will not have a functional impact. I don't see any errors.
Thanks and Regards,
Vibhor Amrodia
Hi Vibhor,
thank you for this, I did lose connectivity during the change after the newly upgraded standby failed over and owing to a lack of time, rolled it back straight away, I will re-test and be more persistent with my troubleshooting, if required.
Darren
Hi Darren,
I don't think these errors would be related to this connectivity issue that you saw.
I would suggest keeping a console logs for the complete migration window.
Thanks and Regards,
Vibhor Amrodia
Please check if all Interfaces have a standby ip! Fix it, then you should not see this warning again.
Configuration > Device Management > High Availability and Scalability > Failover > Interfaces
