UCM GDPR
Hello Cisco World
We are in the process of adding several new UCM clusters to our existing environment.
These are configured to exchange route strings and patterns via ILS/GDPR.
One of the clusters joins the ILS network and successfully advertises its route string and local patterns to all other clusters
but does not import any GDPR from the other clusters on the network.
Has anyone else seen this problem.
ILS service is active. I have restarted this several times on all clusters.
The node registers to the ILS hub ok. Im using password for ILS authentication.
I have tried setting the affected cluster as the hub. I accepts registrations and disseminates the GDPR info to the other clusters in the network.
I have rebooted the entire cluster.
Nothing works. Im stumped
Has anyone else had this issue?
Thanks in advance
Manish Gogna
Hi Gerard,
If GDPR has been set up as per "Set Up Global Dial Plan Replication" of the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmfeat/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100_chapter_011101.html#CUCM_RF_AF960479_00
and the issue still persists after cluster reboot then i would suggest engaging TAC to troubleshoot it further.
Manish
Thanks for that Manish.
The cluster is setup as per the doc and the import of advertised patterns from this cluster is working on the other three clusters, but it does not import any advertised patterns from the other three clusters.
I have a TAC case open so hopefully they can find a solution.
Gerard
