05-21-2015 08:55 AM - edited 07-05-2021 03:16 AM
Pardon my newbie-ness. I have a 3602e access point that is out of the box new. I am trying to get it up & running on my LAN. Our Primary network switch is a Catalyst 3650 in which I have configured and enabled a WLAN. I have configured option 60 & 43 in my DHCP... however the 3602 does not seem to locate the switch/controller. What am I missing here?
I do not currently have any other Cisco access points on this LAN.
05-21-2015 11:08 AM
can you attach the config of the switch port where you are connecting the AP,
printshots of the controller wlan and management interface interface configuration, controller AirOS version ??
05-26-2015 08:17 AM
Hi All. Thanks for your many responses. After finally rebooting the switch over the weekend, I have been able to get the 3602e to join the controller. It is broadcasting my SSIDs like I want it to.. Clients are connecting & picking up IP addresses. That looks good. HOWEVER... none of the clients can ping my gateway.. so clients have no internet access. Everything looks correct now, so I am at a loss. Let me know what additional information you might need from me, I will post it ASAP.
thanks
05-21-2015 12:40 PM
Post as well how you configure the VCI on your DHCP Server including ASCII value plus the Predefined Option pointing to the VCI.
05-22-2015 03:46 AM
Refer the configurations and upgrade example guides: http://www.cisco.com/c/en/us/support/wireless/aironet-3600i-access-point/model.html#ConfigurationGuides
05-22-2015 06:32 AM
Hi All. Thanks for the replies. I managed to work around some of my own stupidity, and now I can see that the 3602e & the 3650 are at least talking to each other. The 3602 is now cycling through flashing blue, and then alternating red/amber/green. When I look in the Controller GUI, I am seeing many AP Join attempts, however 3602 never joins. The log is telling me the following
May 22 12:18:12.892: *%LWAPP-3-AP_LICENSE_REQUEST_ERR: 1 wcm: License request failed for AP d0:72:dc:ec:35:f0 - AP License Request timedout, ensure MC link is up, Resettting AP
I am pretty sure the licensing is activated. (see attached).
What's next?
05-22-2015 06:48 AM
I may have answered my own question... It seems that the 3650 is still acting as a mobility agent & not the MC. I need to find some downtime to reboot it & hopefully it will be all good.
fingers crossed.
05-23-2015 02:13 PM
What controller and what code are you running ?
05-26-2015 08:18 AM
