Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929664members
1244471discussions
Community Activity
Spoke stuck on IKE state in DMVPN
Hi,We have mGRE DMVPN tunnle between one Hub and 7 Spokes. Other 6 Spokes are working fine but one Spoke is not connecting to Hub.Spoke shows DMVPN on IKE state (tunnle is not working) and Hub is not adding nhrp entry in table.Spoke DMVPN TunnelPleas...
INBKIT_0-1713981579965.png INBKIT_3-1713982713738.png INBKIT_4-1713982931986.png INBKIT_5-1713983001947.png
INBK-IT by Level 1
  • 137 Views
  • 5 replies
Does Aeromexico have 24 hour cancellation? ✈️ Aeromexico
How Can I Speak to a Aeromexico 픸핚핣핝핚핟핖핤 Representative Fast?  【Aeromexico Guide 헙헮혀혁 & 헙혂헿헶헼혂혀】 Talk to someone on Aeromexico 픸핚핣핝핚핟핖 smoothly, give their dedicated support line a ring at + ퟭ-877 ✈ 559 ✈ 0161 . Take your time and listen carefully t...
How do I get a refund from Aeromexico? 【✈️ Contact Now .
How Do I Get A Human At 𝗔laska 𝗔irlines Immediately? #AA @USA
T헔lk to someone on 헔l헔sk헔 헔헶헿헹헶헻헲 smoothly, give their dedic헔ted support line 헔 ring 헔t +(((ퟭ-ퟴퟬퟰ-ퟴퟴퟲ-ퟬퟴퟴퟲ))). T헔ke your time 헔nd listen c헔refully to the 헔utom헔ted prompts, then sh헔re 헔ll the required inform헔tion to help them solve your problem quick...
Cisco ISE 3.2 OVA instable crashes
Hi  Everyone,Cisco ISE 3.2 keeps crashing several days after the installation.The installation has been done successfully without any problems.After a couple of days the installation is malfunctioning.After several installations and change of the sel...
Tom -K by Level 1
  • 92 Views
  • 3 replies
CBS350-8XT too noisy
I own a CBS350-8XT that is far too noisy. I even purchased a sound meter to obtain a measure and it goes up to 70db where the maximum indicated in the user manual is 41.3db. I would like to open a ticket or something for cisco to fix my unit. How sha...
How Do I Really Get Through To 𝗔laska 𝗔irlines? #AA @USA **
Cisco 2960S not pinging, but has DHCP address
Hi,I am trying to set up an SSH connection to my switch, but right now there is some lower level problem. I have set up my FastEthernet0 interface to ip address dhcp and the command show interfaces FastEthernet0 shows the correct address. Even if I t...
limex by Level 1
  • 75 Views
  • 6 replies
[UCS B]「DCOS process error ( Reset reason 3#012)」によるIOMのリブート
2024年4月21日 (初版) TAC SR Collection主な問題 「DCOS process error ( Reset reason 3#012)」によるIOM のリブートが発生する場合があります。 【ログ抜粋】 /UCSM_A_TechSupport.tar.gz/sw_techsupportinfoもしくは/UCSM_B_TechSupport.tar.gz/sw_techsupportinfoーーーOBFL:0:process_check:IOM REBOOT in 10...
Resolved! VPN Tunnel connecting at a unconfigured setting - Phase 1 Timer
OK, so I've got a set of ASA's and we are migrating them to Firepowers, and all seems ok. In the past we have noticed that for some reason on the ASA's, no matter what you specify as the parameters for phase 1, the rekey timer always connects at 3600...
Screenshot 2024-04-25 142720.png Screenshot 2024-04-25 142752.png StephenCarter_0-1714052852588.png
XE SD-WAN: ACL ロギングによりルータで予期せぬ再起動が発生する
2024 年 4 月 26 日 (初版) TAC SR Collection主な問題 ACL ロギングを設定している XE SD-WAN ルータ (通称: cEdge) で予期せぬ再起動が発生する場合があります。 原因 この問題は CSCwc28587 として報告されています。CSCwc28587 - C8300 : Crashed without generating any core (Critical process plogd fault on rp_0_0 (rc=75)予期せぬ...
Issues Launching Cisco Catalyst Center
Hello,I am trying to launch the Cisco Catalyst Center Cisco DNA Center Release 2.3.3.5 with ISE and it does not seem to be working. I have not received an email to launch through VPN either. Am I doing something wrong? I tried yesterday also with the...
pbiggs by Level 1
  • 8 Views
  • 0 replies
