05-21-2015 10:59 PM - edited 03-08-2019 12:07 AM
%SMC-2-BAD_ID_HW: Failed Identification Test in 0/-1/-1 [7/0]
The module in 0/-1/-1 in this router may not be a genuine
Cisco product. Cisco warranties and support programs only
apply to genuine Cisco products. If Cisco determines that
your insertion of non-Cisco memory, WIC cards, AIM cards,
Network Modules, SPA cards, GBICs or other modules into a
Cisco product is the cause of a support issue, Cisco may
deny support under your warranty or under a Cisco support
program such as SmartNet.
I See this error on my 2900 series router.Disgusting thing is it keeps on repeating this message every 60 Seconds. It is my new router.I think needs to be replaced.
version info is as follows
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.1(4)M10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 24-Mar-15 13:38 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
router32ki-b uptime is 37 minutes
System returned to ROM by reload at 08:13:57 EEST Fri May 22 2015
System restarted at 08:15:50 EEST Fri May 22 2015
System image file is "flash:c2951-universalk9-mz.SPA.151-4.M10.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
11-24-2020 08:48 AM
What was the resolution to this problem? It isn't only seen on the 2900 platform.
11-24-2020 11:43 PM
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva42524/?rfs=iqvred
M.
