Simulation Testing using GNS3
fatalXerror
Level 5
Level 5
Hi Experts,
Good Day!
I'm simulating a topology which is attached in this discussion. Technically, the design should the ISPSW1 is just L2 so that the ISPRTR1 and the FW will be point to point peers.
My question is that my ASA's port channel pointing to the ISPSW1 is not going up for some reason and my config in the ISPSW1 is correct.
Need your expert opinion. Please see attached files.
Thanks.
On ISPSW1 you have configured port-channel1 whereas on ASA you defined port-channel10.
Hi vivek,
Thanks for the feedback, you mean that it should be the same port-channel number? Because I already tried it but it is still the same.
