Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928559members
1242121discussions
Community Activity
PXGrid 2.0 High Availability - Primary Pan Outage
I have an EVE-NG lab that consists of a Panorama, 1 FW, and 4 ISE nodes (see lab.jpg attached).  The Lab ISE nodes are running 3.2 patch 5 and panorama and Firewall is running 10.2.7-h3.  In reading the 3.2 and 3.1 admin guides they both state in the...
ryanbess by Level 1
  • 86 Views
  • 1 replies
network with subnet
I’ve twins subnets. They need renew up each 3 hour. People think stranger when I said that is a awesome approach. So when I’m taking care from the network I need break for renew ip for them.
Renewall of Admin Certificate
I have to renew the admin certificate in a pair of ISE nodes (Prim / Sec) on Version 3.2.0.542 Patch 4. Currently both devices have the same admin cert that expires in little over 3 weeks. All the names and IPs in this thread are placeholders. I gene...
Sergio C by Level 1
  • 236 Views
  • 11 replies
Pseudowire over XRd not working?
Hi, We´ve been using XRd as a way to do integration testing with our autoprovisioning platform using gnmi.This works great.However I'm currently trying to do end to end testing of the whole solution with actual traffic forwarding across the finished ...
SA2 by Level 1
  • 366 Views
  • 21 replies
unknown IPs in FTD outbound logs
I am managing FTD-1120s with FMCv both running v7.2.1 software.  In my ACP I have a GEO rule to block all outbound traffic to China, Russia, and I few other "hotspots".   When I search for events that match this rule, most of the traffic is from inte...
tato386 by Level 6
  • 126 Views
  • 1 replies
  • 1 Helpful votes
Disable PPTP and L2TP server
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
mo01 by Level 1
  • 344 Views
  • 15 replies
CiscoISE policy applying on switch problem
Hello,I have a problem with applying policies from CiscoISE 3.2 on switch C3750. It simply doesn't stop the unauthenticated users from logging in to switch, nor it prevent commands that are forbidden by the created policy. In Live Logs I can see that...
mitros by Level 1
  • 304 Views
  • 17 replies
Help with extended access list
So I've been working on my project and I've implemented vlans nad also router stick.Now I want to block connections between vlans that are not same with extended access list but something does not work..Here are the commands that I've writtenip acces...
Trustsec Network Authorization not Working
Hi All,I am newly building trustsec in my environment,trying to add one of the switch under trustsec. Have configured Trustsec settings and COA on the ISE for the switch and added the appropriate aaa commands , radius servers and cts commands.But sti...
Catalyst 9600 シリーズスイッチで、接続されていないインターフェースで LED が点灯する場合がある
  2024年4月23日 (初版)   TAC SR Collection主な問題 Catalyst 9600 シリーズスイッチで C9600-LC-48TX を使用している場合、このモジュールでケーブルが接続されていないにも関わらず、インターフェースの LED が点灯する場合があります。これは LED 点灯上の問題となり、機器の実動作に影響はありません。 本事象は 17.9.x / 17.12.x でのみ発生する事象として報告されています。 原因 この問題は、CSCwi04837 として...
Cisco ACI - ELAM capture
Hi All,I am geting below alert while configuring ELAM on ACI leaf switch.Can any one suggest on this.module-1# debug platform internal tah elam asic 0Invalid CLI for platform type - TAHalso can some one share the procedure to perform the ELAM capture...
Robo123 by Level 1
  • 18 Views
  • 0 replies
