Voice services on Cisco Jabber for iPhone/Android
Sergey Lubenkov
Is it possible to disable voice services on Cisco Jabber for iPhone/Android and use it for IM only?
Hi Sergey,
The deployment guide mentions this mode as well, please check table 4 of the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_5/CJAB_BK_D6497E98_00_deployment-installation-guide-ciscojabber/CJAB_BK_D6497E98_00_deployment-installation-guide-ciscojabber_chapter_011.html
Manish
Manish Gogna
Hi Sergey,
It looks possible. As per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Android/10_6/rn/JABA_BK_CB805EB4_00_cisco-jabber-for-android-10-6-release_notes.html
We support Cisco Jabber for Android using IM only mode on all Android devices which meet the following minimum specifications:
  • Android OS 4.1.2 or higher to Android OS 4.4.x
  • 1.5 GHz dual-core or higher (quad-core recommended)
  • Display 320 x 480 or higher
  • Cisco Jabber for Android does not support the Tegra 2 chipset"
Manish
Hi Manish,
I think they meant something different under that sentence because I couldn't find any references how to disable voice services.
Sergey
Hi Sergey,
Manish
Hi Manish,
You was right. I've removed device profile for iPhone from Call Manager and Voice Services are gone. All other features are available though. Problem solved.
Thank you,
Sergey
