05-26-2015 01:11 AM - edited 03-17-2019 03:07 AM
I am tying to setup up a CUCM 8.6 lab using VMware and Gns3. For where i can get gn3 c3700 ios with voip functionalities?
I have a 3700 ios but it not supporting voip and also not showing voip modules to add.
Please help me.
Mohit
Solved! Go to Solution.
05-26-2015 01:53 AM
No that wouldn't support voice. It adds Security related features to the IP base image. As said previously download and use the advanced enterprise version it has pretty much everything.
-Terry
Please rate helpful posts and mark the thread as answered if you have no other queries.
05-26-2015 01:30 AM
Download the advanced enterprise IOS - it will have full features. Now where to get is if you have valid CCO download from there but it appears you dont have that - Google how to get that.
I will not suggest any non-legal method here but if you google you would find a lot of sources as per any other software.
-Terry
Please rate helpful posts.
05-26-2015 01:46 AM
Hi Terry,
The ios version i am using is Cisco IOS Software, 3700 Software (C3725-ADVSECURITYK9-M), Version 12.4(3), RELEASE SOFTWARE (fc2).
Does it support Voip , if yes how to make it work ?
Mohit
05-26-2015 01:53 AM
-Terry
