05-26-2015 12:28 PM - edited 03-10-2019 12:26 AM
Basically I want to be able to use the other 2 ports as I would a switch and assign a VLAN to all of them. Here is the current configuration:
Cisco Adaptive Security Appliance Software Version 9.1(6)4
Device Manager Version 7.4(2)
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.0.120.1 255.255.254.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
Need to extend the inside interface to ETH 0/2 and ETH 0/3 so we can connect other devices in that network to them.
I image I would just clear the inside interface config on eth 0/1
create a subinterface on eth 0/1 and add the ip address to that then the VLAN ID and add the nameif as inside
Create subinterfaces on eth 0/3 and eth0/3 and add the same VLAN ID?
I assume I would not have to add an ip to each one of those right?
Will that work?
There is all kinds of docs about mutiple vlans but nothing I could find that ref what I am trying to do. I would think this would be common.
05-26-2015 05:06 PM
Best to add a switch.
You cannot assign same vlan id to multiple sub-interfaces
John
05-26-2015 08:21 PM
But you can on a 5505 with old school 8.2? There has got to be a way to do this.
05-26-2015 10:15 PM
5505 is a bit different and can do this. The higher end ASAs are designed for larger networks where you will have switches
John
