05-26-2015 01:11 PM
Hello, i dont know how to choose router for small business (5-8 pc's).
Internet connection is Vdsl 50/10 and we have ISP router which I can put in brigde mode.
I was looking 881. Is this good choice or we need something else?
can that router work with that internet speeds?
Solved! Go to Solution.
05-26-2015 04:25 PM
All the Cisco 800 series routers are currently End of Life. I would recommend looking at another series of routers.
05-26-2015 04:25 PM
05-26-2015 11:15 PM
Which series to look then?
05-27-2015 01:54 PM
You're best option is to call into the Small Business Support Center and open a case with our presales team. 1-866-606-1866. They should be able to answer any and all questions you have.
