05-26-2015 11:14 PM - edited 03-17-2019 03:08 AM
Hello ,
I have problem with user in Cucm.
The user get locked in active directory.
Please refer to the picture:
In DC the user is locked from CUCM PUB.
any idea?
05-26-2015 11:51 PM
Not sure if that is the case but check the following settings on respective user page if locked check box is checked...
05-27-2015 04:49 AM
The problem is still not resolved .
any idea?
05-27-2015 07:29 AM
If the user is locked in AD you have to go to AD to unlock it. You can't do this through CUCM.
05-28-2015 08:36 AM
If CUCM is configured for LDAP Authentication, and you are trying to authenticate to CCMuser page with incorrect credentials it can lock the account on AD. If it is happening fairly frequently it will be easy to tack. i would suggest running a PCAP on AD server to capture authentication data. There are other application which use end user authentication to login example CAD, Jabber ETC they could also be a potential issue.
Jitender Bhandari
