Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928488members
1241964discussions
Community Activity
Forward traffic from subnet to another on C3750
hi guys thanks for your suggestions in advancehere is my lab setup sorry for the primitive drawing(TYPO in CT2 Bib1/0/12 it is actually 123.123.123.242/30)i modified ips to fake ones. 10.0.22.1/24 is one of our vlans that has full internet access.CT1...
gabecz by Level 1
  • 0 Views
  • 0 replies
BGP using Layer 3 Switches
Hi All,I have 2 networks connected via OSPF. I need to route the connected networks to a third network via BGP.I noticed that BGP peering is established but no entry is visible on the routing table.Below is an extract of BGP config:router bgp 65200.1...
Ranjita by Level 1
  • 114 Views
  • 7 replies
Resolved! RADIUS and local login
At my new job, I was told RADIUS hasn't functioned for over a year.  I wiped the RADIUS server settings and started from scratch.  I'm happy to say, after going thru every cisco device, ALMOST all devices now login via RADIUS flawlessly.  There are t...
Marcus023 by Level 1
  • 220 Views
  • 3 replies
StealthWatch SSL/TLS Client Identity Certificate
Uploaded the Trusted CA Root certificate to the "Trust Store" in the SMC. Then I generated a CSR from the SMC "Additional SSL/TLS Client Identities" and signed it by the CA server "Windows server", but when I upload the new signed certificate and cli...
Upgrade Cat 9300 and 9500 No Reboot
Is there a better way to upgrade these yet?Obviously, I want to reboot after-hours. The install command still cannot be scheduled.install add file flash:cat9k_iosxe.17.09.05.SPA.bin activate commit prompt-level noneIf I do not do prompt-level none th...
Need help on how to setup static routing Using CBS350
Hi, I'm trying to configure a connection between 2 house network as in the image and I need help on how to configure the switch to make all device able to connect to device on the other network. I've check both router and see static routing menu on w...
Capslock by Level 1
  • 101 Views
  • 2 replies
Webex Question
I was recording my meeting & I saved it to my computer. Once it was ready I tried to watch it & it seems that it didn’t download correctly. I saved a video before no issues . I recorded another no issues. Is there a way to convert the file? I can vie...
nishhk2 by Level 1
  • 40 Views
  • 1 replies
EPNM:backup logの取得方法について
 はじめにbackup log作成方法についてbackup log取得方法について参考情報  はじめに 本ドキュメントは、EPNMでのbackup logの取得方法について説明しております。    backup log作成方法について まず、EPNMサーバへsshログインし、CLIからbackup-logsコマンドを使用してログを作成します。#backup-logs <ファイル名> repository <repositoryの名前>   ファイル名は、任意の名前で、repositoryの名前は...
akkojima by Cisco Employee
  • 14 Views
  • 0 replies
Memory Utilization exceeds 85% on Cisco Nexus 3548 How to fix this ?
sw# show system resourcesLoad average:   1 minute: 0.33   5 minutes: 0.38   15 minutes: 0.31Processes   :   576 total, 1 runningCPU states  :   0.25% user,   1.00% kernel,   98.74% idle                CPU0 states  :   0.00% user,   0.00% kernel,   10...
Cisco Firepower 2130 Site to Site VPN Connection to AWS
Hello,   Good Day, Seeking help from you guys, currently I`m configuring Site to Site VPN connection from Cisco Firepower 2130 to AWS. I`m using the download configuration from AWS which is Cisco ASA 5500 9.X file, and I`m using Cisco Firepower 2130 ...
9800 WLC-Same Vlans on multiple sites in SD-WAN setup
I have a 9800-CL in an SD-WAN setup. I have multiple sites that have the same Vlans at each site to make it easier to manage and remember.Ex:NorthSite: data-4, voice-5, wifi-6SouthSite: data-4, voice-5, wifi-6etc...My current WLC configuration has on...
GeorgeC71 by Level 1
  • 66 Views
  • 1 replies
