Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919302members
1223483discussions
Community Activity
Anyone help me with this topology
1. Make end to end connectivity first. 2. Block the network for these site   1)Make sure that Site 4 will not advirtise any network to Site 5 which it receiving from Site3 routers.  2) On site 5 , when we check routing table of R2 router,  it dont ha...
URL Logs
So, I'm task with finding if anyone else search or connected to a specific URL in the last 30 days. Does any know if FMC have a way of searching this or generating a report. I have only found ways to create a rule to log it go forward not from the pa...
Pining between devices is not working
Hi, im having issues pining between devices, i also cannot figure out how to connect the D1 switch and R1 router. Password for secret is class and normal password is cisco. Would appreciate any help or guidance! thank you !!
jushb001 by Level 1
  • 9 Views
  • 0 replies
Not seeing debug dot1x or mab event log entries on IOS-XE machines.
Hello all,20+ years ago I used debug all the time, however not so much so in the last decade. Seems like last time I called TAC on the 3850 debug command they gave me some silly answer that debug was a Cisco TAC command.  WFIW All the Cisco.com debug...
wags by Level 1
  • 127 Views
  • 3 replies
how to modify TTL to less values at routers?
Assume that there are three router type devices outside firewall, and one core switch router behind one layer firewalland I would like to hide the router hop of core switch router from traceroute how to modify TTL to less values at router at the most...
Maivakov by Level 1
  • 119 Views
  • 4 replies
Resolved! Replacing spine by a different spine model
HELLO, i have cisco aci fabric with many pords, one of my pods are made by 2 x Cisco Nexus 9332C spines connecting 16 leaves with 4 uplinks for each leafs.I already used all the ports of the spines and i want to replace the 32 ports Cisco Nexus 9332C...
ANAKIN_TN by Level 1
  • 709 Views
  • 9 replies
  • 1 Helpful votes
What is the purpose of this equipment..Senior artists
A = cisco N9K-C9504This is a tool that was included in the equipment packaging box while mounting the equipment A. What is this tool used for? It looks like earwax, so my grandmother covets it. Please advise quickly. Thank you, mastersPlease understa...
seedmon by Level 1
  • 43 Views
  • 0 replies
Dhcp server with vlan's
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
TS40 by Level 1
  • 106 Views
  • 1 replies
VRF Leak Configuration
        VRF Route LeakAs already we know that, Virtual Routing and Forwarding (VRF) is a technology for creating separate virtual routers on a single physical router. Ro...
Gopinath_Pigili_0-1711683498667.png Gopinath_Pigili_2-1711683525711.png Gopinath_Pigili_3-1711683877641.png Gopinath_Pigili_4-1711683925500.png
Ruckus 7150 to Cisco 3750 trunk port not working
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
oowJ by Level 1
  • 165 Views
  • 4 replies
Cant make call from jabber api - jabber web sdk
Hi team, is anyone out there very familiar with the Jabber Web SDK? I don't understand much about this and we have a situation here where we are using the Jabber Web SDK and the firefox extension, we see that our aopi registers with the call manager ...
csrlima by Level 3
  • 389 Views
  • 2 replies
