ā05-28-2015 05:29 AM - edited ā03-08-2019 12:14 AM
I need to remove a line "snmp-server community...." from a running config, how do I do it? I know I can edit the notepad config file from tftp then load that file to the switch, but i think there's an easier way without rebooting the switch. I'm thinking of typing "No snmp-server community..." but I think there's a way to delete the line.
Hubble
Solved! Go to Solution.
ā05-28-2015 05:49 AM
You are correct. To remove a line from a running config, type
no snmp-server community....
Easy way to do it, is copy the line that needs to be erased, then go to
config t
type no "then paste"
and enter.
Hope this helps.
Please rate helpful posts.
Thanks.
config t
and enter.
Hope this helps.
Thanks.
ā05-29-2015 08:55 AM
Thanks Charles :).
