05-28-2015 08:34 PM - edited 03-11-2019 11:01 PM
I'm labbing with 2 ASAs and having problem pinging from "host" to "ISP-1" and "ISP-2"
Failover on the ASAs. I can reach ISPs from ASA itself, but not from the host. icmp are allowed on the ASAs inbound and outbound.
access-list OUTBOUND_TRAFFIC extended permit icmp any any echo
access-list OUTBOUND_TRAFFIC extended permit icmp any any echo-reply
access-list INBOUND_TRAFFIC extended permit icmp any any echo
access-list INBOUND_TRAFFIC extended permit icmp any any echo-reply
access-list INBOUND_TRAFFIC extended permit icmp any any unreachable
access-list INBOUND_TRAFFIC extended permit icmp any any time-exceeded
on the Host node, I have its default-gateway as ASA's inside interface.
this is debug ip packet detail on the Host node:
Router#ping 10.0.0.1
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
*May 29 03:13:08.665: FIBipv4-packet-proc: route packet from (local) src 1.0.0.5 dst 10.0.0.1
*May 29 03:13:08.665: FIBfwd-proc: packet routed by adj to GigabitEthernet0/1 1.0.0.1
*May 29 03:13:08.666: FIBipv4-packet-proc: packet routing succeeded
*May 29 03:13:08.666: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending
*May 29 03:13:08.666: ICMP type=8, code=0
*May 29 03:13:08.667: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending full packet
*May 29 03:13:08.667: ICMP type=8, code=0.
*May 29 03:13:10.665: FIBipv4-packet-proc: route packet from (local) src 1.0.0.5 dst 10.0.0.1
*May 29 03:13:10.665: FIBfwd-proc: packet routed by adj to GigabitEthernet0/1 1.0.0.1
*May 29 03:13:10.666: FIBipv4-packet-proc: packet routing succeeded
*May 29 03:13:10.666: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending
*May 29 03:13:10.666: ICMP type=8, code=0
*May 29 03:13:10.667: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending full packet
*May 29 03:13:10.667: ICMP type=8, code=0.
*May 29 03:13:12.665: FIBipv4-packet-proc: route packet from (local) src 1.0.0.5 dst 10.0.0.1
*May 29 03:13:12.666: FIBfwd-proc: packet routed by adj to GigabitEthernet0/1 1.0.0.1
*May 29 03:13:12.666: FIBipv4-packet-proc: packet routing succeeded
*May 29 03:13:12.666: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending
*May 29 03:13:12.667: ICMP type=8, code=0
*May 29 03:13:12.668: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending full packet
*May 29 03:13:12.669: ICMP type=8, code=0.
*May 29 03:13:14.665: FIBipv4-packet-proc: route packet from (local) src 1.0.0.5 dst 10.0.0.1
*May 29 03:13:14.666: FIBfwd-proc: packet routed by adj to GigabitEthernet0/1 1.0.0.1
*May 29 03:13:14.666: FIBipv4-packet-proc: packet routing succeeded
*May 29 03:13:14.666: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending
*May 29 03:13:14.666: ICMP type=8, code=0
*May 29 03:13:14.667: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending full packet
*May 29 03:13:14.667: ICMP type=8, code=0.
*May 29 03:13:16.665: FIBipv4-packet-proc: route packet from (local) src 1.0.0.5 dst 10.0.0.1
*May 29 03:13:16.665: FIBfwd-proc: packet routed by adj to GigabitEthernet0/1 1.0.0.1
*May 29 03:13:16.666: FIBipv4-packet-proc: packet routing succeeded
*May 29 03:13:16.666: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending
*May 29 03:13:16.666: ICMP type=8, code=0
*May 29 03:13:16.667: IP: s=1.0.0.5 (local), d=10.0.0.1 (GigabitEthernet0/1), len 100, sending full packet
*May 29 03:13:16.667: ICMP type=8, code=0.
Success rate is 0 percent (0/5)
when I do packet tracer on the ASA, everything shows ALLOWED:
packet-tracer input inside icmp 1.0.0.5 8 0 10.0.0.1
1.0.0.5 (host)
10.0.0.1 (ISP-1)
I'm using VIRL for labbing.
05-28-2015 11:46 PM
Have you enabled ICMP-inspection?
fixup protocol icmp
With that you don't need the ACEs for the return-traffic. But that's probably not the problem.
On the ISP-router, you can do a "debup ip icmp" to see if the pings reach the ISP-router.
05-29-2015 06:18 AM
Sorry forgot to mention "inspect icmp" is on
i haven't tried debug on the ISP side.
