Warning message
OOB management help
May 29th, 2015
Good afternoon,
I'm working on figuring out why some remote branches cannot be managed by dialing in. The line dials and appears to connect, but in the terminal nothing ever shows up.
The configuration is this:
line 0/3/0
 modem InOut
 transport input all
 stopbits 1
 speed 115200
 flowcontrol hardware
The two bolded statements were missing, and I put them in. I thought this would solve the issue, but it has not. Our configuration seems to be the same on working routers as the configuration above. We are using 2911's with 15.1XXX if that helps.
